1 - 2 of 2 Posts
I wish to install an EV supply and utilise spare capacity I have in an existing Hager CU rather than installing a secondary CU. My EV Charger needs Type A protection with a C Curve rated at 40A.
Could I install a Hager ADA190U RCBO (1 Pole) or should I install a CDA263U RCD (2Pole) and a NCN140A MCB?
I am concerned that the simpler RCBO installation is only a 1 Pole device and the Neutral will not be switched if tripped.
You need a dedicated 2 pole RCBO or dedicated MCB+RCD.
The RCD cannot protect anything other than the EVSE.
Sent from my SM-N976B using Tapatalk
1 - 2 of 2 Posts
