To be honest I haven't used many public chargers. That will gradually change, but with a high range EV like the Kona I find much of my life luxuriating in easy-as-pie overnight "home" charging. I see lots of anecdotal stories around why chargers fail, and experienced at least one. What I am not sure about is whether we're really understanding the full problem. So here are what I think are the reasons I think why a charge might fail and I'd like you're input to see what the top reasons are:
a) Cannot find chargepoint, it's somewhere hereabouts, but...
b) Unacceptable location, eg dark and at night, insecure
c) Inaccessible charger, eg behind a physical barrier
d) Broken/damaged charger connection, eg it's been smashed on the foor and in serious need of repair
e) Car problem, your car simply fails to charge at this type of charger
f) Charging handshake problem, eg it starts and stops. Lots of potential issues here, including very slow charging.
g) Financial problem, eg credit card, RFID card not recognised
h) App problem - not sure if it is the same a f)
i) No/poor internet connectivity
j) Charger completely dead, ie no electricity
k) Cannot read charger display because of sunlight
L) Wrong type of connection, eg CSS, Chademo, Telsa ...
M) Damp/rain/ice etc
N) Inuse - someone else is hogging THIS chargepoint
O) Adjacent inuse - slow charging because you're next / nearby to someone else who is hogging the juice
P) ICE etc vehicle blocking access
Q) Other unknown charger issue
That's my brain dump on the subject. We can blame Ecotricity, or any other company for not maintaining their chargers. My quest wants to understand how much is caused by the car we are driving, lack of planning on our part as humans, payment issues, and how much is down to the charge point provider.
I've seen for example a charge point design in Norway where the charger cable cannot easily drag on the ground and so should get damaged much less. In contrast I've seen some ecotricity connectors looking pretty bad. Is that an inherent design failure where the female bit that goes into your car's charge point is damaged physically? Or are there a handshaking problem between car and charge point caused by poor car charging design as much as the charge point itself.
I thought about running a poll, but decided against that at this moment. What I'd like to do first is to get comments back so we can get the options right and decide if the idea has any meaningful legs.
