Has anyone found a compatible hitch yet? Here is some info I found.
https://www.etrailer.com/p-24976.html
Expert Reply:
I spoke to my contact at Draw-Tite and they informed me that the Draw-Tite Sportframe Trailer Hitch Receiver part # 24976 will fit your 2018 Hyundai Kona EV. This hitch is a custom fit that installs using pre-drilled holes in the frame. Once you have the trailer hitch installed you will then measure from the center of the hitch pin hole to the outer edge of the bumper. This measurement will be needed to help select the best bike rack for you. The bike rack also needs to be rated for use with a class I hitch.
For example, the Thule Doubletrack Platform-Style 2 Bike Rack part # TH990XT will require at least 6" from the center of the hitch pin hole to the outer edge of the bumper while folded and 6-5/8" while laid flat. It is also compatible with a class I trailer hitch receiver. I have attached a review video for you as well.
Expert Reply:
