After 14 months of ownership familiar message I know and after a full charge it comes on when you switch the car on in default Normal mode/KERS 3. Usually after 10 - 20 miles you don't get this message again as there is battery capacity available to take the generated watts.
The car was serviced at the end of October last year where the BMS update was applied to allow charging with the door unlocked or open. I don't seem to be affected by a massive drop in range and battery shows 456V when at 100%.
Using my home fast charger I have toped the battery up to 100% a few times. Balancing takes about 3 hours. Since my last full charge two days ago the 'Regen Braking Limited - Use Brakes' message now appears every time I toggle to KERS 2, KERS 1 and back up to KERS 3! This occurs at all state of charge of the battery. This morning it came on again even though the battery is just on 4 blobs or about 50%.
Any similar experiences?
