Hi,
2 quick questions:
1 - do the brake lights come on when you’re regeneration? I was goingdown a hill last night and couldn’t see the lights come on behind me but I did see the lights come on when I hit the brake pedal.
2 I’m currently going into zero Regen for max coasting as I drive mostly out of town. Does the brake pedal in ‘zero’ Regen before normal friction brakes? Ie Is leaving it in ‘zero’ and then braking when required means I’m still getting the same Regen energy as level 3 but one method uses the paddles and the other uses the brake pedal?
Thanks.
2 quick questions:
Thanks.
