1 - 3 of 3 Posts
Hi guys . Title sort of speaks for itself but I’m fitting a rear seat in my kangoo 33kw and wondering if it’s possible to unbolt the battery to get under to bolt the seat rails . Is there any clearance between the battery and van floor? Thanks In advance
So the rear seats are in an the best way to do this is to fit seats with rails that can be long enough to be bolted behind the battery and the front bolts are located where the sub floor is raised above the rear foot well steel . A 6” access hole is required to get infer the van floor as there is a cavity and you are still in the van as there is another skin of steel ( the actual floor pan between the battery )
1 - 3 of 3 Posts
