1 - 3 of 3 Posts
I have done a search, both here and on Youtube, but have found nothing that is appropriate.
Has anyone successfully removed (and preferably replaced) a RH door mirror?
Problem 1. I cannot see how to reach and disconnect the wiring plug buried inside the door frame.
Problem 2. As well as the two 'obvious' screws there is a third fixing in a cast aluminium leg where I cannot see even the style of fixing, never mind get to unscrew it (if it is threaded).
It is a 2018 LCI model, so the mirror cap is 'Universal Black', not body colour.
Thankyou.
Thank you, that is a useful resource I was not aware of.
Removing the door skin seems straightforward, it's the steps to enable that which make the job complicated!
Necessary preliminary work:
I'm not sure about removing the door: there is no guide as to how the door is held secure while the door skin is removed (Release door outer skin outwards from the bottom side with a forceful jerk.).
Thanks again.
1 - 3 of 3 Posts
