1 - 8 of 8 Posts
· Registered
On my Mk8 GTE I occasionally find it necessary to unplug the charging cable before it’s fully charged. I find it is a pain the the arse, requiring the following procedure :-
Get in car. Turn on ‘ignition’. Find e-Manager in infotainment screen. Tap ‘Stop charging’. Turn off ignition. Get out of car. Lock it. Then unlock it. Remove socket.
What a bloody pain. There must be a quicker and more logical way to do this.
Advice welcome.
· Registered
The mark 8 may be different, but on a mark 7.5 with keyfob you just need to unlock the car.
When the car is charging the green light next to the charge point pulses. When you unlock the car it stops charging, the green light goes off and the car releases the charge plug for about 10 seconds. If you don't unplug in time it will lock the plug and start charging again. If it does you just have to press the unlock button again to release it again.
· Registered
And the same for my Passat GTE.
· Registered
Same for Mk7. Arguably it's annoying that it unlocks on key fob. I'd prefer it to only unlock the charge port if you e.g. double pressed the unlock button, because sometimes you want to pop out to the car to get something without interrupting the charging process.
· Registered
It smells a bit of the Mk7.5 deleting the interior alarm disable button - a friend of mine owns a Mk7.5 GTE and always complains that he has to go into the touchscreen to disable the interior alarm whenever he leaves the car with his partner or dog in it (in cold weather of course), whereas on my Mk7 it's a simple physical button just besides the driver's seat. It's a cost optimisation, but it makes some jobs so much harder!
· Registered
There appears two ways to to remove cable socket during charging.
1. The long winded way I described.
2. Unlock with key fob, remove socket within 10 seconds. Easy-peasy.
Begs the question. Why is there a stop charging ‘button’ on the infotainment screen.
1 - 8 of 8 Posts
