1 - 20 of 117 Posts
· Registered
Megane E-Tech EV60
Ok, had another failed charging session last night, I am starting to assume its my charger car combination so thought I would start a thread to collect any others experiencing problems or whether its just unlucky me. Have opened a ticket with Renault Technical to look into it but as its an intermittent fault I don't have high hopes that they will solve it.
So if you want to play the game, list the following.
Charger - [Your charger] e.g. Charge master EVSE (Dumb - not Smart charger)
Failure Mode - Red Rectangle of Death or Blue Constant Rectangle e.g. Blue Constant Rectangle failed on schedule
Don't play the game if you use your smart charger to schedule the charging as that's just cheating! :)
· Registered
I'm not sure I understand your "game" correctly...however my Megane has failed to charge 3 or 4 times. I have a ZAPPI charger that enables charging at 0030 to 0430 when I get a cheaper electricity rate. About half the time the charge doesn't start. There are no lights on the car charger and the ZAPPI says waiting to charge.
Unlocking and locking the car by remote control starts the charging.
It looks to me like when the car has been sat plugged in a while but there is no power, it stops waiting for the power to come on.
· Registered
Renault Mégane E-Tech Evolution ER, Renault Zoe Q210 Intens
I've noticed with a granny you have to connect the charger to wall socket first before connecting to car. If you connect car first then it will result with red rectangle. Probably because it will take some time for the charger to activate (blinks a few secs before going "live").
Could it be your charger or car goes to sleep mode or something, and thus the car thinks the connecting sequence is wrong and create similar error.
My charger also has compatibility mode for 6A. Seems the car doesn't like to start at such low speed so I first have to start in 8A which is the default mode. Then switch to 6A later and the car is happy. I use it sometimes when I wan't less charge and don't bother delaying the charge.
At 6A you can hear a ticking sound before the car rejects the connection.
· Registered
No charging fails 00:30 to 07.30, using BP Chargemaster Wall box and Schedule on the My Renault App. Also always connect the charge lead to the car then to the wall box...then....
I always deadlock the car before charging... twice on the fob.
· Registered
I only charge in daylight and I don't know where you see all these triangles.
Happy to give it a test but what sort of period delay do you want between plugging the car into the EVSE and the car telling the EVSE to give juice?
Are you setting things up in the app or on the dashboard?
Gaz
· Registered
Megane E-Tech EV60
Thanks for your replies, looks like there is only two of us with problems.
So I had a draw last night, car failed to initiate charge using the timed schedule but I forced it to charge via the app.
So charger working but app not. Unfortunately the car kept on charging until I manually stopped it when I woke up this morning so its charged a couple of hours at peak rate but at least I can get to work this morning.
I have opened a case with Renault and will report back if they come up with any solutions besides replacing the charger.
Interestingly the manual charge hasn’t been logged on Zeddy, whereas all the other charges have.
· Registered
Megane E-Tech EV60
Discussion Starter · #9 ·
Here is the Zeddy log showing when I plugged in at 22:15 and it charged for a couple of minutes before I told it to schedule charge via the app for 00:30h - 04:30, this was to make sure the charger was working.
Font Screenshot Number Rectangle Parallel
· Registered
Megane E-Tech EV60
Discussion Starter · #10 ·
Try the game, set your car schedule charge via the app or in the car menu, set your charger to always be on and see what happens. Using the charger to schedule the charging I would expect to work but its interesting that you have had it fail.
· Registered
I've had one session at IKEA where Zeddy logged starting percentage but ending shows empty, so it can bug a bit at times. All you can do is wait for next charge and see if it sorts itself out. Apparently the info comes through some API from MyRenault so ultimately could be that it's not even a fault of the app.
· Registered
Might try the delayed / timed charge tomorrow now that its a bit warmer just out of interest to see if it works. With a Granny I usually don't need to time it because it's so slow I just take all I can get, and I only pay fixed rate.
· Registered
Megane E-Tech EV60
Discussion Starter · #13 ·
I always try and connect to the charger first before the car as this seems more reliable some public ac chargers can be fussy when using your own cable.
The charger has to close its contactors and a green light go on to show that the charger has successfully communicated with the car. There is also a loud audible click when you hear the contactors close. However if it clicks again 5 secs after that then the car goes to Red Rectangle of Death. You can trick the car by putting it to sleep using the key and plug it in and then you get the Blue Rectangle of Hope, but this still doesn't guarantee the app will start the charge. :)
If you set the car to instant charge then the car charges normally with pulsing Blue Rectangle of Contentment, so it suggests that I have two potential faults;
1. Communication error between the car and charger in particular circumstances giving red rectangle of death, car has to set to schedule charging, car has to be awake, charger has to click a 2nd time.
2. Schedule charge fails to start as initialised via the app / Renault servers, this can be checked in the logs to see if the car tried to charge.
· Registered
Megane E-Tech EV60
Discussion Starter · #14 ·
Ahh, you sir are the lucky one, or I am the unlucky one! :)
You sound like you have identical setup to me and you are having a better success rate, I wonder if its time to take the charger off the wall and inspect its innards and look for burnt out cables and worn contactors?
How old is your charger and how many times do you charge per week? Mine is 4 years old and gets used about 4 times per week.
Do you have a Techno, Equilibre or Launch Edition Megane?
· Registered
Megane E-Tech EV60
Discussion Starter · #15 ·
Ohme home pro and octopus intelligent, all done with the ohme app, just tell what % I want the car charged to and by when, it does the rest.
That might be the best solution in the end, get a new smart charger and not use the car's scheduling.
The only issue is whether your Ohme charger lets the car precondition before you set off in the morning. This a feature I use a lot as it stops the car using the battery to heat the cabin and pulls it out of the charger or AC mains instead increasing range and efficiency.
Can you test whether you can do that setting a preheat program and then checking whether it uses the battery or the AC mains through the charger?
· Registered
Megane E-Tech EV60
Discussion Starter · #16 ·
Gaz
Its the charger indicator light, but you knew that :)
Just set the car schedule charge via the app or car menu whenever you like, plug it in at home and see if you win or fail!
Cheers!
· Registered
Megane E-Tech EV60
Discussion Starter · #17 ·
I think your right, Zeddy is just logging the notifications from My Renault, Matt Cheatham will know more. The app didn't give any notifications for the missing charge on the charge log.
Out of interest, last time I had problems with the Zoe My Renault App when the connected services expired last year it started sending me text messages every time it started or finished charging which I found very useful as it logged the time and state of charge. Now I have the Megane I don't get Text Messages anymore which is a bit annoying, anybody else missing there texts?
It was really touching last year when the Zoe was dying at Centre Parks sending me texts for help in the middle of the night as the battery cooled down and went to 4% and it really wanted me to get up in the middle of the night and go and plug it in! 😄
· Registered
Zeddy just pulls the info already stored at MyRenault through API with the help of your login credentials. I only started using it a few days ago and the app got my full charge history.
The information is not even stored on any 3rd party server so the app just pulls data using your credentials which stay on your device, so it's safe to use and all clearly stated when you first start using the app.
It's a bit weird Renault only give you access to this info once the service expires. They could give you a much broader service based on the info they have, but sadly seems most people have smart chargers so probably they don't see a business case there.
1 - 20 of 117 Posts
