1 - 11 of 11 Posts
Hi, tried to hire a Zoe recently but when I pressed the start button the instrumentation panel went blank. You could very faintly see the drive position indicator moving on the panel as the gear-stick was moved from P to R, D etc and the car could be driven forward and back. Of course when the car was checked over the fault had gone away! Just wondered if anyone else has experienced this or whether I had pressed some switch by mistake. Thanks.
Ampera aka IGOR
Tesla Model 3 P
Not knowing much about the Zoe but when I had an Ampera out for a test drive I got a bit of a fright when suddenly all the dash lights faded to nothing, it turned out the automatic lights had come on and the panel illumination was at the dimmest setting.
sounds like somebody was mucking about with the adjustable screen level brightness settings in the R-Link menus-I was having a look at that when exploring those settings myself..
Hi "EV Rider", would the R-link menus adjust the instrument panel or just the sat nav / multi-media screen? thanks
SU-EV convert
Jaguar iPace 2020
where did you hire it from ? I'd quite enjoy that
I think it covers both..I started fiddlin' when sat at a charger with no inclination to go anywhere in the meantime and found the menu in the settings..I'm sure readjustment would be straightforward..can't think anything you may have done would cause this..
Hi "EV Rider" I've found the Zoe manual on-line and in the Driving Position View of the instruments (page 1.58 and 1.59) it talks of "lighting dimmer for control instruments". If this is set to its dimmest is it possible that you can't read anything on the instrument panel? It was a wet dark morning when I had the problem. thanks.
sounds like the situation you had..glad you got a fix!
A number of years after your problem, I've just come here hunting for the answer to the same question, and this was it! Thanks.
Zoe R110
As an FYI this can be linked to the day/night running transition.
I've had it before where the daylight sensor gets confused as to how much light is outside and it flicks from day to night or vice versa so the display can switch between those two settings. Having the display set to a low level for night time does make the display appear to go off when it is actually sunny outside.
Reactions: BenQ
1 - 11 of 11 Posts
