1 - 8 of 8 Posts
Hello all,
So I found this 2011 Leaf car with DC fast charging is completely dead and AC charging only works after several attempts of charging. Eventually AC charging died too. Diving into the on board charger's circuit, I found out that two capacitors are exploded inside. Since there was no success after replacing these, I replaced the entire on board charger. Still charging doesn't work and through OBD, I'm getting a can communication circuit error DTC.
My question is, is there a serial number kind of thing for the on board charger that we need to reprogram into the VCM somehow, so that the VCM will detect the OBC as a valid module?
get in touch with Mike @ Indra...
Reactions: Mike Schooling
Hello all,
A canbus error would probably point to one of more modules on the bus holding either canH or canL at the wrong level. I doubt a coding error would show up as a can circuit error...
@HughF @roger davis thanks for the help. I already contacted him.
@HughF but the vehicle goes in to the driving mode without a problem. If a module holds canH or canL at a wrong level, the whole EV CAN is inoperable right?
if it goes into drive and works OK apart from the charging then as you say, the vehicle canbus is OK
Reactions: aroshad7
I looked into replacing my 3.3kw charger for a 6.6kw charger, i know some owners have done this job, there was no programming to be done, the car works fine with it, so in my opinion, theres something else wrong, as from what ive researched, the chargers can be swapped out with no problems.
This was for defo on the gen2 leaf, not sure on the gen1 sorry.
1 - 8 of 8 Posts
