I had a Rolec Homesmart point installed last year under the OLEV grant, with all the cabling already in place. Cabling wise, it is a 32A MCB from my consumer unit, into what looks like an RCBO and then into the Rolec.
I recently realised that I needed an EV Charger which may need load balancing, as it would be certainly possible to hit the 100A main fuse limit within the household. It looks as though the Zappi will do exactly this and cut the current to the car in favour of the house, to protect the main fuse. Then, when the load is lifted, go back up to 32A. Great!
I looked at pricing however and it would seem that Zappi V2 installed prices are quite high (others have been quoted £1000-1200 w/o OLEV grant), but I would've thought that also included the cable runs and the labour that is required. I can buy a Zappi V2 tethered for £725 direct from MyEnergi for context.
Would it be a reasonable option to remove the Rolec, and then fit the Zappi myself if the cable run is already present for the Rolec? Two areas that I would be most concerned about are differences in ground/earthing requirements and commissioning.
Or alternatively, would any competent electrician be able to remove and fix the Zappi, or does it require a specialist who can fit Zappi for the commissioning process?
TIA
TIA
