Have you tried ecoharmony.co.uk. They do the Viridian replacement controller for the Rolec. Different grades of unit as more expensive versions are more compliant with electrical standards for todays installations.Anyone able to supply a known working one from a retired unit?
Would like to bring our EV charger back to life, and it's apparently not in stock new thanks to the chip shortage thing.
It's quite expensive if you only need dumb charging and the standards aren't retrospective anyway. I've also got a vague notion that the Viridian controllers don't properly run the Rolec light display... hopefully someone will correct this statement if I'm wrong.Have you tried ecoharmony.co.uk. They do the Viridian replacement controller for the Rolec. Different grades of unit as more expensive versions are more compliant with electrical standards for todays installations.
Now we have brought back to life 1 Rolec by using the same components from another Rolec, I would tend to agree with you. Plug & Play etc. I am also hoping Rolec get some new Mode 3 Controller units in and do not price gouge them,if they are in short supply.@MarkyM I did check out the Viridian controller. While it looks to be in stock, I'm concerned that if it's not exactly the same there's a danger I may not wire it up correctly. My electrical skills are ok up to doing a completely like for like swap, but any changes would be fun I could do without. There are a lot of wires to connect up and the controllers aren't cheap!
I suspect I may be forced (due to supply issues) to feel that fear and do it anyway...
As far as I understand, the only complication is that you'll need to replace the LED if fitting the Viridian because polarity is reversed...@MarkyM I did check out the Viridian controller. While it looks to be in stock, I'm concerned that if it's not exactly the same there's a danger I may not wire it up correctly. My electrical skills are ok up to doing a completely like for like swap, but any changes would be fun I could do without. There are a lot of wires to connect up and the controllers aren't cheap!
Unfortunately, it appears that the Rolec branded mode 3 comm's module ACSE0020 has now been discontinued as I understand it.Anyone able to supply a known working one from a retired unit?
The lady who rented the house said her landlord threw it in the rubbish bin having fitted a new one. She then put it in the recycling bin which was emptied a day before they discovered the zoe still spat out it's dummy when her friend tried to charge at her place.Sounds like they're not people to remove the controller from the innards, maybe they'd like to sell the unit as a whole?
EPC V2, uses common Annode LED's so should work.As far as I understand, the only complication is that you'll need to replace the LED if fitting the Viridian because polarity is reversed...
We can also help with supply of electrical components, such as contactors, RCBO's ect.Unfortunately, it appears that the Rolec branded mode 3 comm's module ACSE0020 has now been discontinued as I understand it.
I was on the look out for one about 6 weeks ago ( to use as a spare ).
Looking on-line, they where either showing as £80 but "out of stock" or a totally "discontinued" item.
Then I received a tip off that a electrical supplier had 6 of them in stock, but they where a lot more expensive at over £100.
I quickly placed an order and about five hours later, they had ALL sold out !.
News travels fast I guess.
It appears that it's the same comm's unit in the 16 amp version.
You could keep an eye out on Ebay for a used 16 amp unit, as these can be a little less popular.
The next item that will become difficult to obtain in the future will the Rolec contactor module at around £13.00 at the moment.
Here is a link to a almost new 7 Kw 32 Amp tethered unit, it will need a Type 2 adaptor or your Type 2 cable switching over from your old unit.
Worth a cheeky offer I think, as this could really work out cheaper than replacing the parts in your unit, IF you can locate them !.
Then you have the spares you need from your older original unit, or maybe re-list the case / cable etc instead to recoup your costs ?.
Rolec Wallpod Electric Car Charger | eBay
Find many great new & used options and get the best deals for Rolec Wallpod Electric Car Charger at the best online prices at eBay! Free delivery for many products.www.ebay.co.uk
Controllers are the same. Just wired slightly differently.Are you after a tethered or untethered controller?
Untethered.Are you after a tethered or untethered controller?
Hi David - Can I ask, are your comm's units 100% compatible / interchangeable with the original branded Rolec comm's units ?.We have a tethered version of our EPC, you would need to change the LED - Lead time 3-4 weeks
Viridian EV EVSE Protocol Controller Tethered 16A/32A
Our EPC V2 - you won't need to change the LED and can also add 6mA protection to your charge point if it dosn't ahve it
Viridian EV EVSE Protocol Controller (EPC) 2.0 Lite
The Viridian EV EPC 2.0 Lite is an entry level option in the EPC 2.0 family of EVSE controllers. It is the same form-factor DIN rail mounted module designed for IEC 61851 compliant EV charge points, but simplified for certain applications. The 35mm wide module can support 1 charging outlet...ecoharmony.co.uk
You can also use discount code Welcome10 to save 10% off your first order
David
Hi Carty,Hi David - Can I ask, are your comm's units 100% compatible / interchangeable with the original branded Rolec comm's units ?.
Are there ANY wiring changes required, when installing the Viridian unit in lieu of the original Rolec tethered branded wall box unit ?.
As there is a three coloured LED warning light on the front cover.
Thanks in advance of your reply.
Honestly, I will be surprised if they arrive at all.I contacted evonestop.co.uk which is Rolec's partner brand/shop front. Still no Mode 3 controllers in stock but she was adamant they would be arriving in May. Although this is the second time I have called and have been told "they are expected in 3 weeks time" each time. But still not in stock.
