Not sure what the steady "1." means? Wrong resistance scale selected? Poor contact? Needs a retry. Fluctuations between 650 & 800 sounds like your paperclips need a bit of a polish up!
Ok, here's the details of the Type-1 gun. You should see 150 Ohms on it's own, 480 Ohms when you pull the trigger. Your meter will register a few more ohms than this, allow up to 10 Ohms for the cable + paperclips, if they're anything lik ehte ones I use.
If the LEDs are lighting up, that's a good sign, I think. If they do whatever flickering pattern they're meant to, even better, means the cpu's actuall working to some extent.
