Our mechanic mentioned signs of rust on the steel frame under our 2012 Opel Ampera.
The manual says Bitumen based undercoatings can damage the original pvc/wax protection. So I went with Teroson WX980 which explicitly says that it is compatible with pvc/wax.
I could not find any other product with that explicitly stated compatibility with pvc/wax undercoatings. Most products are bitumen/asphalt based. I couldn't find any of the products recommended by GM for sale in Europe.
I started removing rust with a drill driven crimped wire cup brush.
I found it very difficult to remove all the rust. So after removing only the loose rust on some of the more accessible areas I just sprayed on the Wx980 anyway. An additional layer after a couple of hours. I'll check the status next year and report back. Our roads are heavily salted during winter.
I also noticed that the plastic undercover on the passenger side had thick layer of gravel and debris on top/inside.
Has anyone attempted some kinf of rust protection for the undercarriage? Has anyone tried applying cavity wax?
I am a bit bewildered by researching rust protection methods, as there are so many different opinions on what products and methods to use.
