1 - 8 of 8 Posts
Hi guys,
I would like to know, is a safety shutter at the outlet of charging station or wallbox mandatory or optional in North America?
Could you please tell me the standard or regulation reference, which I can find this information?
North America don't have ev charging outlets. They use tethered charge points only. J1172 (type 1) rather than Type 2 or Type 3 socket outlets, and as such, don't have shutters on their charge points.
Well, thank you very much for the hint. I think that is the reason, why I can not find requirements for the safety shutter for type 1..
For your information, the mandatory tethered charge points, do you know where does it define?
I suppose you mean J1772 rather than J1172. However, I have not found such sentence inside to say only "tethered" allowed.
Thank you
Thank you
I don't think anyone in America has a cable in their car to plug into a charging station like we would do with at type-2 socket. As far as I can tell it appears the chargers are universally tethered unless you are speaking of granny chargers (Nema 14-50 being a higher power version of this). Would be interesting to see if anyone knows any exceptions to this.
SAE J1772 was the original base standard for AC charging of electric vehicles used in USA and its territories, Canada, Japan and South Korea. It defines a tethered plug connector, and a vehicle inlet socket. The official standards documents cost real money.
Internationally, it's all part of the IEC 62196-2 set of standards, also known as EN 62196-2, so SAE J1772 defines the connector that is mentioned in the IEC standards documents as type 1. That same document also defines the type 2 sockets and plugs that we're used to in Europe for AC charging, as well as the Type 3 sockets and plugs that used to be common in France and Italy before Type 2 for charging infrastructure connectors became more common.
Type 3 sockets were always defined to have shutters on the phase and neutral pins, as well as the CP/PP/contactor safety. It seems that the regulators in Italy liked the idea of shutters as well, and I think the regulations there say that public type 2 charging sockets should have some form of shutter mechanism as well. Shutters are an optional component in the IEC documentation from 2016 for type 2 infrastructure outlet sockets.
The reason why Europe and most of the rest of the world has Type 2 sockets is that they support three-phase AC supply, which is far less common in North America and Japan for most domestic, or even commercial supplies.
Start reading at IEC 62196 - Wikipedia and if you really want to, buy the standards documents.
Thanks a lot for your hints. I have checked the SAE J1772 as well as IEC 62196-2 and found the evidence. In the standards, the connector mechanical configurations have vehicle connector and vehicle inlet with type 1 and type 2, but for socket-outlet and plug are only type 2 available. Therefore, type 1 can only be used with tethered plug.
For type 3, if I understand you correctly, the shutter is inside of the plug pins? Is that right?
But dose Italy use type 2 or type 3? I think type 3 is uncommon in EU. Do you know, which countries use type 3?
Furthermore, have you ever seen some shutters in the type 2 vehicle connector? (I mean the charging connector for the vehicle inlet?)
Discussion Starter #8
you are right. I think so as well. I even found the charging cable, which has the type 2 plug and type 1 vehicle connector.
1 - 8 of 8 Posts
