1 - 20 of 37 Posts
Just seen the prices of the new Enyaq - and they look good value!
Whilst the 80's are all over the £35k threshold - the 60's aren't and actually one is £35370 so I imagine that will be re-aligned to £34995
Whilst it will be a lot slower than a Niro (134KW motor not 201KW) it's an excellent spec for the money and should be eligible for the grant.
Not much cheaper than an ID3 - but definately cheaper than an ID4 which is it's nearer rival.
On the Skoda website now.
Discussion Starter · #2 ·
Just tried to spec one - and you can get a nice one for about £34000 - however that doesn't make it clear whether it's including the grant or not.
Also there are a lot of options that need you to add a second option as well - electric seat for example needed another £600 option added as well to have it?
Anyhow - looks good value, and something I'd definately consider now the Niro 4+ is over £35k and no grant.
I’ve been playing about with their configurator this morning. In contrast to the ID.3 which has many trims and few options, the Enyaq has few trims but a bewildering array of (expensive) options. I’m struggling to find a brochure type page that shows what equipment comes as standard with each trim.
Their range has been nicely split with the withdrawal of the govt grant so that the £35,000+ cars have effectively become £2,500 more expensive. I was looking at the 80 versions for the added range and they are about £8,000 more expensive than the equivalent 60 model if it still gets the grant. I couldn’t justify that much more just for the added range and I’m sure a lot of people will think the same.
I them a slight disservice, the difference is “only” £7400.
60 Loft = £31585 after the grant
80 Loft = £38950 with no grant
I can’t see them selling many of the 80s based on that. It’s impossible to justify as a customer.
It will still sell - it's one of the cheapest 70+ KWh battery cars out there - although I have to say for 77KWh - range doesn't seem that high (336)
So 336 / 77 = 4.3m/KWh.
This sounds ok... but VW haven't been good so far at hitting their claims - so if it's really more like 300 - then that's a lot more money for something with 20m more range than the Niro?
Maybe when looked at against other marques but I think it will lose sales to itself. Let’s be honest, the 80 is buying you more convenience (fewer charges with more of those at home probably). That’s a big premium to pay for that convenience.
Discussion Starter · #7 ·
And certainly if you fall into the normal "Regular commute 20m plus occasional long trips" model the extra range is immaterial 90% of the time.....
I love the convenience of the 280m range of the Soul - but if they did a 240m one, for £7k less I might have gone with that one!
Kia E Niro 4
But in better time when we can go out for a day trip once more visiting somewhere 100-120 miles away which I would consider a reasonable distance for a day out I wouldn't want to have to be looking for a charge on the way home, so personally a range of 240 - 250 would be a minimum
Discussion Starter · #12 ·
Yes - I think you'll be fine in good weather. To be fair if you are going for a day out - I'd be amazed if you didn't stop somewhere for a little so you can usually plug in for 20 - 30 mins.
I am always finding places to plug in - Tesco's, car parks all sorts, half an hour at 7.2KW can add 12-15 miles - which can add a bit of comfort range. 20 mins on a Rapid will add a good 20KW which will add 80m
I have 280m range - and never had any concerns.
Ioniq 5 Ultimate Long Range RWD in Gravity Gold, Eco & Tech packs
Is the El Born full ev or PHEV? - It does look a pretty car - I quite like the Seat's - sadly the Cupras are just too hard a ride for me.
It is a BEV, although a LHD petrol will be available later on in Europe.
VW ID.3 Life Pro Performance, MY22 (software v2.3)
I think the best bet (at least until there's a PDF brochure) is to follow the "More Info (i)" buttons against each model on the "Pick a version" page:
Pick a version
That just shows standard equipment, not options.
It looks to me as though the 80 gets a few extras over the 60 Nav, but I think there are options to add them all in.
Are you sure that a Seat will have normal suspension? Even the Alhambra was only available with sports suspension (on a people carrier?). I assume that means they just take the springs out and bolt a solid bar in instead.
How is this possible? The Born is an ID3 in Cupra clothes so has been designed ground up as a BEV.
I can only apologise for skipping a line on the Eurekar website, it was referring to the Formentor SUV not the Born.
1 - 20 of 37 Posts
