1 - 10 of 10 Posts
do I need to remove the SD card and download software onto it in order to do this?
At the moment it just says service unavailable. Any advice would be most appreciated.
Corsa-e Elite Nav 70 reg
No, you don't need to do anything to the SD card. Sometimes this problem is a result of the emails being processed by Renault in France, so your email provider rejects them. I have this problem with my gmail account, but strangely the calendar works OK with my gmail login. When I first got the car, emails worked, but it wasn't very useful to me, so I don't know when they ceased to work; perhaps after the latest software update?
Don't you need to be registered for one of the monthly access packs ? Pretty sure mine won't open any of the calendar or email apps.
In GMail settings, go to the tab called "Forwarding and POP/iMAP" and enable POP or iMAP as may be required.
I already have IMAP enabled.
I read on an R-Link forum that one solution is to use 2 Step Verification on gmail. I tried this yesterday and ended up not being able to access my emails on android tablet or phone, so I turned it off again.
Just because you can doesn't mean that you should.
i was thrilled to set up the email successfully, but found it no where near as convenient as using a smartphone, so have not used it other than the once.
I agree, but it's annoying when something doesn't work, when it should. One day when I have forgotten or lost my phone, it may be necessary to use the Zoe's email facility. It used to work when I first got the car.
So I tried 2 step verification again and I was able to get my phone and tablet to work this time. I then set up an application specific password for R-Link. However, I still get 'Service Unavailable' in the Zoe.
1 - 10 of 10 Posts
