Should Smart bring back the Roadster as an EV?
  • Yes - It'd be great
    Votes: 17 73.9%
  • Yes - It could do well
    Votes: 6 26.1%
  • No - Stupid idea
    Votes: 0 0.0%
  • No - Good idea, Just not possible in this day and age
    Votes: 0 0.0%
1 - 20 of 25 Posts
I think it could be awesome. Like a smaller Tesla Roadster?
I had a Smart Roadster Coupe, most disappointing car I ever owned (not the worst, just the most of a let down) but with an electric motor and no gear-changes it could be amazing?!
Feasible? Doable? DIY only? Good idea, bad idea?! Am I mad and alone thinking this could be a real winner?
Do yo envisage a high performance machine or something the same as the fortwo ED?
Yeah I think as a high performance car it's something I'd be interested in, but would I want to plunk down £40-£50k on a smart car...?
As a low performance/range car, I'd probably opt for something more practical.
Really?! I had a Smart Roadster too, and we absolutely loved it. Maybe because it was my first car, I'm still sentimental about it.
The gearbox was infuriating though.
They have already done electric conversions of it - http://eauto.si/super-piki-smart-roadster-ev/
But with a €16-30k price tag, it's just not worth it sadly.
Sadly yes. I drove a Smart Roadster pre-launch (neighbour at the time worked for Smart division in Milton Keynes) and it was really, really good fun. Later on I bought one (after a MINI Cooper S) in Coupe spec, metallic blue with silver "tridion shell"...
Too slow, and the gear changes were just terrible, I mean really, you could boil an egg in the time it took to decide which gear to engage. :( It also leaked, forever, sometimes causing electrical issues (a common issue).
Shame because it was a really cool looking car and had bags of potential to be an economical, fun little sports car.... and electric drive could fix almost all the above issues.
I still have a soft spot for the Roadster, it was such a shame it was such a let down as a "proper car".
I agree with all those points! I remember the endless days spent trying to dry the thing out!
The auto was so bad I had it in tiptronic all the time, which helped. #rosetinted
I think the real reason for its promise was the clever way it was built to be light as possible - meaning the tiny engine was plenty of juice for it.
Similar principle for improving range/reducing battery size on early EVs really.
Discussion Starter · #10 ·
I once got locked out thanks to water in the BCU, lucky(?!) I had the Coupe which meant I could crawl through the boot hatch and into the car that way. Very dignified for a 6" tall guy having to do that in a packed gym car park!
So much this, small, light, nimble and efficient... it ticked most of the right boxes for "my kind of car" and I believe it could make a cracking EV if they wanted to. Surely?!
We priced up the parts for a conversion of one of these about a year ago. Came out at about £15k all in (including car) probably about £20k with labour. That was with a 24KWH battery, 7.2KW charger and a approx 80hp/180ftlbs AC motor.
Specs are similar to a top end leaf and would be about half the weight!
Discussion Starter · #12 ·
Did you have a think about what would go where in the vehicle? Coupe or Roadster? Just interested in the packaging aspect of it all.
Yes, Roadster - 24KWH in the space available and keeping weight roughly 50/50 is a big challenge. The motor and drive electronics replace the space taken by the engine. Motor is direct to gearbox however we investigated the possibility of changing the gearbox for one out of a polo due to the gearbox complaints on these. There was also some witchcraft that would need to happen to fit a larger motor in due to issues with drive shaft clearance.
We think that just under half the battery will fit in the rear with the motor in the space taken by radiators, exhaust, fuel tank etc.The rest would go in the front boot. losing around half the space.
Things might change if we were to do it now as battery technology has moved on and we have access to some low profile cells that *might* fit underneath.
this might help you visualise the layout of the car :)
Honda CB125R + Bus
The Roadster had a bad reputation.
I don't think I'd go anywhere near one built on the old platform.
An all new design? Maybe. Depends.
Has anyone given serious thought to converting a Caterham SV?
No but I'm currently looking at a westfield ;-)
@Paul Almost certainly, not failed to convert a car yet!
Not sure I fancy your chances!
1 - 20 of 25 Posts
