1 - 20 of 33 Posts
Hi everyone,
I went to pick up a 2017 24kwh Leaf Tekna today from Arnold Clark (not a Nissan dealer so aren’t offering a battery health report), however I started to doubt the car (and my knowledge) when I noticed it said 57 miles at 93% charge.
The display shows 12 bars, and it only has 26k miles; I know the range indicator is very much a guesstimate, but I expected it to be somewhere around 70...?
I’ve asked them to charge it tonight and I’ll pick it up tomorrow all being well.
What’s should I expect the range to say for a healthy car of this age/mileage? Or is there another answer to how I should approach this?
Thanks!
Stu.
Probably has been driven relatively hard in the last few miles which is what the GOM reading is based on. The only way to assess the battery is via LEAFSpy and then only when it's significantly discharged.
Where abouts in the country are you or is the car?
Yes I’ve just heard about it indicating a range based on recent driving habits; apparently resetting the trip will show the range without that influence?
I’m not up to speed with LeafSpy yet, but guessing it’s not something the dealer would be keen on me doing...
The car is in Newcastle upon Tyne.
I wouldn't buy without seeing leaf spy data personally. An adapter is £20 and the app is free. No reason the dealer would object i can see.
The GOM is based on how it's been driven so doesn't give an accurate reflection of the battery health. Only Leafspy SOH data can provide this.
Read Only
I'm very close to that dealership, and sadly gave away my OBD dongle to a LEAF owner I met at a charger only last week! Otherwise I would have been willing to give it to you, to help with your purchasing decisions.
The fact that it's got 12 bars is promising, and it's one of the very last 24kWh models to be built. Those batteries do tend to degrade slower than the larger variants, and you're probably fine with it - IF you ask yourself this: Worst case scenario, you're about to drop to 11 bars. Would the car still be suitable for your needs, and still priced suitably for such a battery condition?
If you can't get a dongle in time, can you test drive it? A bit of sensible driving should quickly bring the range estimate up after only a few miles if the battery is good. Ideally with eco mode and limited heater use. Alternatively a quick blast down the motorway won't help the GOM but would show if the battery discharges at an expected rate or not.
You're probably fine, especially with a more recent model like this but obviously leafspy would always be preferable for full peace of mind.
A bit of advice-you are buying this at the wrong time of the month. ALWAYS buy a car in the last few days of the month, never at the beginning. The dealerships are always far more willing to negotiate sensibly when the end of month figures are looming large in their thinking. Another point to consider is the outside temperature. I have been frankly amazed at how much difference the outside temperature makes to the actual range of the Leaf.
You are in Newcastle, not particularly noted for it's sunny, warm climate......
At the end of the May the temperature will be considerably higher than during this present cold snap. I have been very surprised how much difference in range I get when the temperature shown by the Leaf display has 5 bars as against 4 bars. In my 30 I can get less than 8-9 miles per 10% of battery charge when it is cold outside - 5-10deg as against well over 11 miles per 10% battery charge when the temperature is over 14deg and there are 5 temperature bars showing.
Hope this helps.
Tony.
EDIT- Dodgy 0 key not 1% !!
Reactions: Gospelman
Amazon have the dongles I got one next day for £22
This works fine. I haven't got it to connect with Bluetooth but works fine with WiFi. I would be amazed if Arnold Clarke don't have their own adapter in fairness. It's standard to leafspy these cars before buying.
I you have paid a deposit the dealer will be perfectly fine waiting a few days to complete the transaction.
I don't know what the trend degradation is on 24kwh leafs. It's 2% a year on the 30kwh leaf. At 4 years old I would be expecting it to have SOH of 92% or better. There is a battery degradation thread on this forum which has all the graphs etc on degradation.
That said it's dependent on pricing and your requirements range wise. You can always use it as a negotiating tool if it's a bit lower or worse than trend. Leafspy also tells you number of charges QCs etc and you can see if it has any weak cells. Essential check really before buying.
2017 30kWh LEAF Black Edition
I'm in Durham, not so far from you. You are welcome to borrow my dongle if you need to. I can also give you a tutorial on Leafspy as well.
If you don't decide to go ahead with this purchase have you thought about Classic and Electric Vehicles in Durham? They specialise in used LEAFs and from their descriptions seem very transparent about range SOH etc.
Don't forget the "significantly discharged" part of my advice. "Bad" cells in the battery will generally charge to a similar voltage as the rest of the battery, but discharge quicker resulting in you reaching a flat battery quicker than you'd like. This can be seen best at below the 10% VLBW (very low battery warning) on the LEAF 24. Do not trust the SoH figure, Hx is more meaningful. If the dealer will not let you measure the car at a low battery level walk run away. To be fair, Arnold Clark know nothing about their stock so will not know if they are selling you a lemon, but rejecting a car is much harder than not buying it unless you are certain it is a good one.
Also check that the SD card is in the head unit and the condition of the strut tops, it isn't unusual for the drivers side to be a swimming pool with associated corrosion of the strut top bearing.
The LEAF 24 is a good car but like all cars there are bad examples. Expect to pay around £7,500 at most from a dealer.
Discussion Starter · #13 ·
Thanks everyone, I’ve arrived this morning and it’s now on 62 miles at 100%, I’ve reset the trip but it didn’t change. They’re being good about it and I’m probably going to take it, get it checked with LeafSpy and return it if I’m not happy with the battery condition.
Discussion Starter · #14 ·
Well I bought it, fully expecting I’d need to check the battery and hoping that I wouldn’t need to return the car.
Started with ‘62’ miles range, drove 14 miles home, got there with ‘68’ miles range 😂
I’ll plug LeafSpy in as soon as I get a dongle to see a better picture, but that has certainly put my mind at ease and I’m absolutely delighted with the car.
144082
Thanks for the guidance everyone, was very useful to help me decide what to do!
Stu.
Discussion Starter · #19 ·
If you feel that way about Arnold Clark, why on earth have you just given them almost 10k of your money!?
😂 Fair point; I was just venting. Just some frustration over their handover process...
I ordered it from a dealership in Manchester and the offer was to move it to Newcastle where I could test drive it and pay if I was happy. I’ve done that with Bristol Street before who were very good at this sort of distance selling set up.
At Arnold Clark though, the dealer at this end just wants rid of you and the car; they’re clearly not making anything from the sale, or very little. The way they talk to you is just to move things along and don’t mind telling you they’ve got a customer appointment soon etc etc.
I just get frustrated with companies who don’t value customer service, or indeed customers.
1 - 20 of 33 Posts
