1 - 5 of 5 Posts
I've hacked in a way to display SOC% on the oldest 2011-2013 LEAF! The solution wasn't as elegant as I'd hoped for 馃槀, but now I don't need to take out Leafspy to check the SOC anymore! More info in the video description for anyone curious
It might be neater if you swapped the values around.
Use the hours field for 0, 1, 2 x 33% and the minutes field for the remainder.
So 50% would show as 1:17
66% would show as 2:00 etc?
It would mean the unused digit goes away, and also puts the numbers the "right way" around where we expect the larger field on the left.
Also, for ease of headmaths, a round number like 20 or 30 might work better for the multiplier?
Infact if the multipler was 50, it'd be even simpler. below 50 you'd get 0:00 thru 0:49 and above 50 you'd get 1:00 to 1:50 (or 1:49, 2:00)
This is a great idea, BUT, the minutes side only increments in steps of 6, so the only possible values for this is 0-6-12-18-24-30etc. So to do that you'd have to accept some rounding, but I wanted a display that shows true SOC. Dang limitations of the ZE0 :D
1 - 5 of 5 Posts
