1 - 4 of 4 Posts
Hi all i seem to be haveing a problem chargeing at home when i plug in it gets going up to 30 amps and charges at 7kw as normal but then afer a few minites cuts back to about 17a and 4kw
i read on here others had the problem and stoping and restarting the charge sorted it out.
but when i stop the charge on the phone app and wait a few secs it just restarts by its self at the same slow speed.
so i tryed on the car screen its self pressed stop charge and nothing happrerned it wouldnt stop only way to stop it was to press unlock that stoped the charge so i disconnected the cable then reconnected but still only 4kw charge speed.
can any one help or do i need to contact service.
thanks for the reply yes was wondering if that could be the problem but you can never be sure when the next update will be
Renault Zoe 50
Shouldn’t be too long, they do try and push updates if there’s a known issue.
Make sure your are connected to a good WiFi signal.
1 - 4 of 4 Posts
