1 - 4 of 4 Posts
EV Charging Specialists - SPEAK50 for £50 off
Hi everyone,
Hope your Monday is going great!
Check out some of the features from our Smart+ here!
Thanks,
Liam
Discussion Starter #2
A breakdown for anyone not able to see the pictures:
Track:
See a detailed breakdown of your charging history, including how much energy was consumed, and the estimated carbon dioxide emissions associated with your charging.
Schedule:
Set the time you want your car ready by each day. If you have Economy 7, no problem - we can ensure your car only charges on the off-peak rate.
Boost:
Override smart modes for a ‘Boost’ charge, to fill your car quickly when you need it.
Over The Air:
We can remotely add features and updates to your Smart+ and Kaluza app.
Hi everyone,
Thanks,
Liam
View attachment 114802 View attachment 114804 View attachment 114806 View attachment 114808
Liam,
I’ve just had this charger installed. Please tell me how it can be setup to charge during Eco7 hrs only? It only seems possible to set a time for veh to be ready by which just seems to reduce charging to trickle charge if over a long period.
Why is there no option to permanently activate “boost” mode like a toggle rather than having to select it on every charge session. Lots of ppl just want to charge at the max rate possible when plugged in. I’m thinking of changing to octopus to take advantage of the 5p kwh 4hr window overnight but don’t see how the current schedule option will enable this automatically to charge at Max rate within this window only.
Finally is there a fault at the moment as I can’t activate boost from the web portal. I press the boost button and nothing changes in the portal or on charger. But it works fine if I press it on the charger it changes blue and the portal shows it in boost mode and boost button changes to stop boost option.
Thanks Jamie
Liam,
Thanks Jamie
Hi Jamie,
Thanks for contacting me on SpeakEV.
I'm sorry to hear this.
Could you please directly start a conversation with me, and provide your name, email, postcode and phone number?
I will then raise this internally with support for you.
Thanks,
Liam ⚡
1 - 4 of 4 Posts
