I've tried to make the cruise jerky and I'm struggling. The only that is jerky is when you use the high regen (3) and lift off then it will try to slow the car down a lot. so hit the toggle down to set and then lift off.
Also, and I do appreciate that you're renting your car, by not using the brakes they'll rust up and degrade faster than they should. Which might not affect you for servicing but even if the car is fully insured etc. you'll still be inconvenienced if you can't stop in an emergency situation because the brakes are corroded.
I get best fuel efficiency in regen 0 with auto regen turned on and I just lift off. If there is nothing in front of you, you coast. If there is something in front of you, you get regen braking. And to slow down or stop you give the brakes a decent shove to keep them clean.
It works for me.
It works for me.
