The SOH is like a counter which counts downwards at a rate of 0.01% per 7 days if there are no interventions, when there are interventions then these can be a sudden and dramatic overnight loss in the SOH reading, in one intervention I lost 1.39%.
Interventions seem to be triggered when the battery is below 5% SOC and seems to be more pronounced in cold weather conditions, the effect is not seen immediately but usually 5 to 10 days later. Usually once the SOH drops down, it rarely recovers, however once I did have a SOH recovery of 0.48% for no apparent reason, so it can happen but in my experience a rare event.
That said, I wouldn't get too hung up on the SOH, other than using it as a marker for the battery's ability to retain and dispense energy and it's use as a trigger for the loss of indicator bars for warranty claims.
Using Leafspy, a more useful reading is the "KWh Remain" when the battery is fully charged to 100% and cells balanced, this is the available range the vehicle has. The lose of available range is significant, especially in winter conditions, where travelling distance might be tight, without stopping for a charge.
The "KWh Remain" does vary by as much as 1 KWh depending on weather conditions, in winter when it's cold and battery internal resistance is greater, then the reading is lower. When warmer in summer it is reasonable to expect "KWh Remain" to increase.
The "KWh Remain" can be boosted by high battery discharge such as driving at 70mph for a sustained period followed by several Rapid charges. But this boost is not permanent and any gain is usually short term and the battery reverts to previous capacity reading.
Also using Leafspy to check for weak cells and the range of disparity between low cells and high cells are the main areas to concentrate on.
