1 - 4 of 4 Posts
Hi,
Using Canze software to measure my SOH gives a bizarre result. It shows 41 when Renault test shows 98. Is there a different app I should be using for a Kangoo?
Sounds odd, have you got your CanZE set to the correct vehicle?
Presumably your Kangoo does a reasonable amount of miles to a charge?
Cheers
Yes I get about 70 at the moment. There is no option for Kangoo or am I missing something?
It’s not really supported. The drivetrain is close to the Zoe but you can’t fully rely on the result.
Your soh must be reasonable if you get 70 miles out of it.
I’ve always liked the look of the Kangoo, I’ve thought about getting one and making it into a passenger version as a little local run around vehicle.
Cheers
130121
1 - 4 of 4 Posts
