1 - 20 of 73 Posts
· Registered
I got a quote through SolarTogether and sort of assumed it is a good quote. It is part of a group buying scheme by the council, I thought it is probably as good a value I am going to get - plus a vetted supplier. But I have had some great responses to my other question and somebody pointed me to a Youtube channel "The EV Puzzle", where Nigel talks about a 14 panels system costing only £4K in the video from earlier this month. The quote now doesn't seem good at all, so I thought what people think.
The installer has quoted nearly £3.7k for 8 panels (includes everything incl. installation over slate tiles) and jumps to £4.3k for 10 panels. There is a quote for battery too but I am not keen on getting that just now.
· Registered
My quote for 12 panels exactly the same panels as yours was £4600 without optimisers as I dont have any shade but my inverter was probably bigger at 4.2kW. Very impressed with the panels. virtually every panel being caked in pigeon droppings after the long dry spell didn't affect output anywhere near as much as I feared...very minimal. I had quotes for solar edge and ja solar panels but other installers seemed unable or unwilling to apply for dno permisson for a bigger than 3.6kw export so I went with the Longis and eventually a bigger system @ 95p per watt.
· Registered
Discussion Starter · #7 ·
When was this fitted please?
I don't have any shade either but an optimiser has been included, I will ask if that is really necessary. Thank you
· Registered
Leaf 30kWh, HS PHEV
From what I remember, just the scaffolding costs 1500 or so. Add additional grand for labour.
Like mentioned about get as many as you can install.
I was starting to look at scaffolding for DIY however I’ve spend my meagre savings on 6.6kW charger for Leaf30 and Phev Box for outlander. Additional panels will have to wait a bit
· Banned
I paid £6k in Feb 2019 for 14 high end 300w Italian panels and a "Solar Edge" Optimiser system that deals with a tiny shading issue in high summer, but is very very efficient. And this still in the FIT Era.
Contact Tanget Solar , @Trevor Larkum runs it along with another great guy Jason. They did an excellent job for me. If you want a basic 4kw panels / invertor system not high end fancy i suspect they will get close to £4k now and certainly should be able to beat £3.7k for just 8 panels.
Solar & Battery Installed Together - Tanjent Energy (tanjent-energy.com)
I'm sure Trev will be along to say hi too.
· Registered
Last time I checked, a 345W panel was around £130 each - you do the maths for 8 panels. I'd go with microinvertors rather than optimisers, but ymmv. I'd expect scaffolding eats a lot of that 4 grand. I got a price for a simple scaffolding to the chimney - £1200+vat.
I also had a quote from one of the those council group schemes. More out of interest to see what they would quote. I thought it was too pricey and I had no input on the choice of kit being used. Also I was a little wary on the warranty claims. They'll be buying panels by the thousands, so will get really good discounts.
Why no upload a photo just showing your roof+orientation and get some more feedback from here...
· Registered
I didn't read your reply before I responded, but I agree. The real winners are the scaffolding firms. Their pricing is a real eye opener, for assembling about 150 metres of tubing and some boards. I guess there must be plenty of work, so they can price high. They are all vat reg too so that immediately adds another 20%.
It might be cheaper to hire a tower, or a cherry picker...
· Registered
Leaf 30kWh, HS PHEV
Yeah been looking at HSS tool hire. I need to climb the second story roof and the way they did extension (previous owners) means there is a 1m gap between top floor and ground floor.
· Banned
BTW solar unless you can consume it makes no sense without batteries now.
Makes less sense maybe, but you can sell you excess solar in the market now, Octopus Energy used to pay good rates in 2020. I got the last of FIT and deemed export so until they pay over 6p kwh in the open market any time of day i would be worse off.
· Registered
Leaf 30kWh, HS PHEV
I have no idea what Octopus pay. Some tariffs are not eligible for outgoings. My day rate is 14.2p so unless they are paying equivalent it makes no sense exporting.
Battery would also enable charging at off peak hours and satisfy background usage
· Banned
None of the post FIT , even 2019 FIT like me, pay enough to give up FIT payments plus 50% deemed export if you actually consume over 50%.
I think 5p kwh, maybe 5.5p was the best on the open market in 2020. I suspect if leccy prices keep going up 5%-10% p/a, eventually they will be offering 20p kwh, when we are paying 50p kwh is normal!!
· Registered
Last month :)
I'd find out how much extra its adding to the bill for optimisers, nice to have but not really needed for zero shading. ( for 8 panels just a couple/few hundred extra maybe..) and get some more quotes! These guys can give good initial quotes from their living room without barely lifting a finger so get as many as poss with all equipment listed.
1 - 20 of 73 Posts
