1 - 9 of 9 Posts
Hi
Had our Soul EV updated Weds for ABS and since having it back the Sat Nav doesn't work nor does the Uvo App and it no longer tells us there's a speed camera. Does anyone have any idea how to fix all of these issues pls? Thanks
Hi
What model of Soul EV?
Kia Soul EV 2020
That will be about the 5th time been back with various issues. Its just not good enough. What are Kia playing at!
What were the other issues?
TBH, my Soul hasn't missed a beat, so far so good.
Soul EV 2020
I'd expect you to have to re-initialise uvo if you've had an update - do it just like the first time pin code on the app etc
Ditto switching on the speed camera warning
If there's no sat nav then it's presumably a failed update - only option is to go back to dealer
You might need to do a reset on the infotainment screen. A paperclip in the small hole on the unit. Check the manual for its location.
If that does not work try a reset of the car by disconnecting the negative battery lead for a short while. You may lose some settings like radio stations when you do this.
If that does not work it will be back to the dealer.
1 - 9 of 9 Posts
