1 - 17 of 17 Posts
Some people do, I don't, I can't pretend not to be slightly worried by the lack of spare situation, but that's common to most new cars nowadays. I do carry a bottle Jack and a non gunking compressor, in the hope that if I return to the car to find a flat I can get enough air into a tyre to get moving without filling a tyre with hard to remove gunk and giving a tyre shop a good excuse to write off a tyre. I haven't had to test the theory yet, long may that continue!
I had a slow leak through the side wall at about 3000 miles. I used the electric pump that came with the car to drive to the dealer to get a new tire. Easy peasy. No weird tire go used at all.
2020 Hyundai Kona Premium SE 64kWh, Ceramic Blue
I have only needed to use a spare tyre twice in the last 20 years (not for the Kona), my last car had a similar pump and tyre weld equipment instead, in the first case I pumped the tyre up and was able to continue on to a tyre garage, for the second case I had a 90-minute delay sorted out by the RAC driving me and the tyre to a local garage and back. Overall saving the extra weight and space of a spare tyre doesn't cause me an issue.
Having looked on the web to other people's experiences, they say
the spare will only fit the front wheels?
" IT DID NOT FIT! The brake caliper blocks full installation of the small wheel. You can't fully tighten the wheel and it forces the brake pad on the disk. I decided to keep the $250 spare tire & kit anyway for use if I get a blowout in front."
What size wheel and tyre did you buy? Some other owners have also found that not all compact spare wheels fit on the rear, and a fullsize wheel is recommended.
If you get a rear blowout, swap your spare with a front wheel first, then swap that good front wheel with the rear flat...no worries.
What Electric Pump that "came with car"? My 2020 Ultimate doesn't seem to have one. Only a can of REPAIR FLAT that fills a tire with Goop to repair hole until I get to a repair shop.
Yes, my 2019 came with a little can of goo and a small 12V electric pump. You connect the two and the pump pushes the goo into the tire. But you can also use the pump without the goo. Just a little bit of fiddling with the connector since the can is missing. Double check your stuff. Maybe you have that too.
Thank you for the warning.
I tried my space saver on the car. It just touched the rear brake calliper perhaps by the thickness of a sheet of paper. It went on but would not rotate and warping under load could make it worse so no slight fettling of the calliper I am afraid.
On the front no problems at all, a large space all round.
So annoying, makes a rear puncture longer to fix but at least I will have a spare.
I forgot the compulsory photographs:-
The rim:- I was assured it was from a Niro Hybrid.
131447
The tyre:-
131448
Witness marks from the calliper touching.
Without seeing the geometry, might some spacer washers fix that ?
Not really, the interference is circumferential not axial. I suspect you could grind a few millimetres off the edges of the calliper but it is not worth it as it will fit the front OK.
It's strange. Front brakes are always (AFAIK) larger (in disc diameter) than the rear, so the design of the Kona rears must be very chubby.
I wonder if it's to do with the parking brake system.
1 - 17 of 17 Posts
