If the tyre pressures are the same, front and rear, then put a new TPMS sensor in the spare and get it programmed to the correct pressure. If pressures are are different then you will have to choose which pressure you get it set to.
Either way a tyre dealer should be able to supply/fit/program the TPMS sensor.
