1 - 7 of 7 Posts
I'm quite confused about the differences between these after watching several youtube videos. From what I understand, AP looks after the steering, is turned off by braking or signalling and is best used on motorways or big A-roads. TACC keeps you a set distance behind the vehicle in front and stays on until turned off manually.
Does AP also have an element of staying a set distance from the car ahead? When would you use one and not the other? Or should they both be turned on at the same time on motorways?
Thanks!
M3 LR+ AWD white/19" alloys/tow hook.
Autopilot describes the combined functions of TACC & autosteer. Yes autosteer is turned off by braking or signalling & TACC remains on until manually overridden.
A single click downward will activate TACC, controlling speed, travelling distance & collision avoidance (braking/warning) whereas a second click also turns on auto steer.
Therefore you can either use only TACC or TACC + autosteer. Tesla advises that they are meant for Motorways/dual carriageways but with caution... many use them on other roads too at own risk.
However phantom braking can happen at any time using AP & means that greater attention is required than driving manually, with ensuing higher potential stress levels!
Additional note: when activated, TACC/AP will automatically accelerate to the speed limit (traffic dependent) and set speed can be adjusted using the scroll wheel.
I can’t remember if it automatically adjusts set speed to the local limit.
As for when to use it, TACC can be reliably used anywhere really. Autosteer can be a bit questionable around town.
Nice. I guess that’s a toggle option in the control panel, and activation is still the single click?
Yes, It's a toggle option that dictates whether, when you pull the stalk down, it sets at speed limit (+ new % offset option) or at current speed. You set the toggle once to "current speed"and (at last) it now behaves like most other cars when you set TACC
1 - 7 of 7 Posts
