1 - 20 of 54 Posts
HI....if the driver became incapacitated ....how would a passenger be able to stop the car?...there is no handbrake as such?
Ioniq 5
Handbrakes are for parking, not stopping the car.
The regen braking in a Zoe is probably stronger.
Same as in a LEAF where there's a foot-operated parking brake - turn the ignition off.
2014 Model S
I thought you could pull the EPB on and hold it on to do emergency braking in all EPB cars?
2017 Golf GTE
Now what do you do when there's no EPB switch? Like on my ID3.
Autohold comes on when the car stops, provided you have enabled it. But all slowing down and stopping is done via the pedals. Also there's no ignition switch. The car detects the key in your pocket and turns itself on. Actually there is an ignition button but I don't know what happens if you hit that while in motion . The transmission lock is in the gear change on the far right well out of reach of a passenger.
Is my car a death trap?
Full 5 stars from EuroNCAP of course!
I think I'll get a prayer book for the glove compartment.
I believe Zoe has a feature where the car will stop in lane after approx 20 seconds of no steering input - it does have “hands off” detection as part of the half-finished lane assist, because I remember my rental shouting at me despite regular input.
Although with no ACC (and no AEB on early models), you’ll probably be screwed long before that.
2020 Zoe ZE50 135 GT Line
If you genuinely have concerns about this, maybe get a lift with someone else?
😂 Oh goodness. No laughing matter though!
There must be a Parking Break somewhere? The Zoe has autohold for when you come to a stop, but it activates the brake lights so I don't tend to use this feature if I know I'll be stopped for long periods (though the autohold will change to the PB after a certain amount of time).
It's inconsistent from manufacturer to manufacturer.
Pressing the start/stop button while driving
There are different scenarios here - what to do in the event of the driver being incapacitated seems to be dealt with by applying the electronic parking brake in most cars but for cars without one it appears that pressing and holding the Start/Stop button is the only alternative although it doesn't appear to use the brakes in most cases.
VW Passat GTE
Grab the steering wheel and aim for the nearest tree. Works wonders when brakes fail, so I presume it'd also work well when the driver fails.
VW Passat GTE
Showing your green credentials with Arbo-cide?
The tree was conveniently positioned at the top of a hill, so it was a case of wrong/right place at the wrong/right time. And thankfully it turned out to be a very sturdy tree.
The ignition on a Leaf 40 won’t switch off at speed, I’ve caught it a few times because it is above a cubby hole directly below it.
Not sure about a Zoë but I suspect it’s probably the same.
You need to hit something more forgiving than a tree, they are pretty immovable objects unless it’s a weedy little tree!
Then they don’t have much stopping force, you don’t really want to find yourself having to select the correct tree in such situations! 😂
It’s a shame that digital photography closed all the snappy snaps branches, they were good at stoping range rovers, but I’m sure that they would be equally useful for EV’s
140263
Read Only
Any car with push button start should ignore a quick press while moving but still shut off after pressing and holding.
1 - 20 of 54 Posts
