Creaky windscreen is driving me nuts though and will be speaking to the dealer about it.
@Flyingstoo has been able to locate the issue with the front windscreen creaking wind screen and found a fix !.
Mine has the same problem, some times you can hear it emulating from over on the passengers side, then some times it is on the drivers side, sounds like it is right in front of the steering wheel.
The noise I can hear coming from the passengers side ( while I am driving ) sounds like a cross between a rattle and a tight creaking trim noise.
If you are outside of the car and in the location where the rubber seal contacts against the front windscreen, if you push down on the rubber seal with your fingers, you can replicate the same creaking noise you can hear inside of the cabin.
I just need to find the time to investigate how to lubricate this seal, at the point where it comes into contact with the front wind screen glass.
I think
@Flyingstoo was able to remove some of the screws that secure the windscreen wiper cover and then lub the seal with a type of silicone grease and refit the cover ?.
He has cancelled a planed appointment to the dealer in order to fix this problem, on the pure strength of his ability to find a fix to this problem himself !.
I am also hoping to be as successful in curing this irritating creaking noise WITHOUT having to pay a visit the dealer, which is a 140 mile around trip O.B.T.W.
