1 - 4 of 4 Posts
Yesterday the Charging Flap wouldn't open in 2017 30kWh Soul from the switch inside the car. I eventually worked out how to do it manually, and it started working again without me doing anything. I am pretty sure its not been cold enough for it to frozen.
I will clean the area with WD40 and take it in for a warranty repair if it happens again.
Has anyone else had this fault? If so what did you do?
I've had mine stick in cold weather and had to pop it open with the manual release under the bonnet... We also had an issue where it would open but not pop across all the way, WD40 solved that for us.
1 - 4 of 4 Posts
