1 - 8 of 8 Posts
Ampera aka IGOR
Does anyone know the paint code for Summit white? I've just noticed a chip on the roof that isn't looking to great, may be rust may just be dirt but I want to get it seen to soon.
I think the handbook details where the information plate is but I forget off hand.
My father in law is a panel beater and he had quite a job finding the code for my Lithium White Ampera, He advised that it is normally found on a serial plate on the kerbside door frame but that wasn't the case for the Ampera.
He went direct to Vauxhall to get the code.
Obviously I would ask him for the code but you have the Summit not Lithium White.
40R/GAZ - OLYMPIC / SUMMIT WHITE ( 1#93165427 )
I think !
And you're correct I don't think it's on any part of the vehicle
Ampera aka IGOR
Thanks, I had seen 40R & GAZ mentioned in a site for Chevy Volt touch up. I might see if my local non-Ampera dealer can order some as it was also showing for the Mokka elsewhere on the web.
I think something on these should be the paint code for Summit White although the touch up calls it Olympic white it is a good match.
1 - 8 of 8 Posts
