1 - 20 of 20 Posts
Hi there,
during my studies about 10 years ago I designed a software to perform preliminary design of electric vehicles.
It is quite accurate (within 5% or so for range) and validated against Zoe, Tesla model S, eNV200, etc...
It can compute range (with or without regen), 0-100kmh time, etc, depending on physical parameters such as test drive sequence (fully editable), vehicle characteristics Scx/weight/tires rolling resistance, battery characteristics etc...
You can find the standalone SW here (it is for windows 64bit), just run the interface.exe application (no virus, I designed it myself!)
Help manual is here, only french, but SW is english based:
some screenshots herebelow:
138615
138616
Hope this will help !
Vianney
When you say "geared motor" do you mean single fixed speed or a multiple speed gearbox? I'm interested in the plot C=f(N) blue plot.
Banned
Does the green line, bottom left chart look correct to you? Only the rpm per volt no load (kv) is changing...
400v bat, 0.045ohm 2 phase resistance, kv variable 10kv-35k, 700mm tire, 8.66:1 gearing, 100% throttle, 735a motor current limit, 207.5a battery current limit, 0.32 drag coefficient, 2.28m frontal area, 1.225kg/m^3 air density, 4000 pound mass, bldc - 126mph top speed w/ ~81kW motor output.
Discussion Starter · #10 ·
(400v bat, 0.045ohm 2 phase resistance, kv variable 10kv-35k, 700mm tire, 8.66:1 gearing, 100% throttle, 735a motor current limit, 207.5a battery current limit, 0.32 drag coefficient, 2.28m frontal area, 1.225kg/m^3 air density, 4000 pound mass, bldc.
Well I don't understand the plots ;) ..
Banned
Well the green line in the top right chart is the same as the red line in your chart (Newton meters motor torque) but instead of rpm at the bottom we have ground speed after the motor output is run through an 8.66:1 gear reduction and a 700mm diameter wheel.
Discussion Starter · #12 ·
bottom left green chart is not torque, it is labelled thrust in pounds. Thrust is then related to torque by the mean of wheel radius.
So for 10kv 0pmh 4000pounds = 18kN, looks definitely too high, because 18Kn with 0.35m wheel radius would be 6300Nm, while top left green line indicates 700Nm of torque maximum... So yes there is something weird !
Banned
yes. I am not expert in electric motor control, but what would be the benefits of this type of motor ? BLDC motors can also be controlled in speed by PWM on the voltage, aren't they ?
This one for my skateboard shows it better...
I have 70kv motors giving me 240lbs thrust (more than 1 to 1 thrust to weight - max 30mph top speed), but if I can pull out the stators while I’m accelerating, I can keep the peak of the purple horsepower line in the top right chart at the same speed I’m going while I accelerate to a much higher top speed, giving an acceleration advantage compared to a fixed higher or lower KV motor.
Discussion Starter · #18 ·
ah yes looks interesting indeed !
1 - 20 of 20 Posts
