1 - 2 of 2 Posts
EV Convert
2020 iPace HSE.
If you have a timed charging / preferred charging window set up, but no departure time set, the Goodbye Screen popup just tells you 'No departure time set'. It does not allow you to choose to use timed charging or not.
The issue that arises from this is that the window it is still active but you can't turn it off. Arriving at a rapid at a time outside of that preferred window, the car went into 'waiting for timer' and with 'Timed charging' on the display, and in the App. The workrounds I've come up with are either to set a dummy departure time some time ahead then use the popup to say 'No', then delete the dummy departure; or delete the preferred charging times and re-add them after the charge. Neither appeal.
Anyone know how to turn the preferred window on and off?
EV Convert
2020 iPace HSE.
Discussion Starter · #2 ·
Well I've managed to answer my own question. Page 2 of the My EV panel.
This is not in the manual and it's not in the current version of the iGuide.
138585
1 - 2 of 2 Posts
