I will be travelling down to Colwyn Bay in the next few weeks from Lancashire, anyone used the Engenie rapid charger at the Talardy Hotel St. Asaph? Or can recommend any other chargers in the area. Thanks.
Just to say, that I have made a quick "Pit Stop" into the Talardy Hotel to check out the rapid charger a few weeks ago.
I did not require any juice at the time, but wanted to see the set up there.
It's a Marston's hotel / pub that is right on the corner of a round about.
When you leave the A55, you will take a steep down hill slip road, when you enter the roundabout at the bottom, it is the third turning on your left hand side.
As soon as you drive under the A55 express way above you, start indicating left !.
You will see the hotel tucked into the corner, it is built right on the corner of the roundabout.
As you pass the hotel on your left, you will see the opening to the car park on your left hand side.
As you enter the car park, the rapid is directly on your left !.
It is in a good spot, because it is at the bottom of the car park.
Most people want to get parked right by the door to the pub / hotel.
It's very short 2 min walk into the pub.
It has a contact payment system on the unit if I remember correctly.
I also applied for an RFID card for use at other units.
I think it was £10 and it arrived in about 3 - 4 days.
There is also a Ecotricity rapid on BOTH sides of the A55 only a few miles further along the A55.
They are both in the service / petrol area's on either side of the A55 express way.
It will be just before the Abergele exit, when traveling DOWN to the N Wales coast.
I am pretty sure it's a SHELL station up on the left hand side of the A55.
When you have passed the exit for Bodelwyddan Castle / Glan Clwyd hospital A&E on your left, you only have about 1 - 2 miles to travel before you see the Shell garage elevated up off the express way.
To use the Ecoctricity rapid on the return journey, it will be the services straight AFTER the Abergele exit.
The charger is right by the Starbucks.
I am not 100% sure, but I think it is an Esso station ?.
Both services have the same post codes of :- LL18 5XW.
They are almost directly opposite from each other on the express way.
I have never used them, so I am in no position to judge their reliability, sorry.
Hope this is of some help !.
