Hi
What tyre pressures do people use and recommend on a 24kW Tekna?
Whatever the cause of your tyre tread wear, 38psi was not it!I ran 38psi on my 24kWh Tekna and it wore the centre of the front tyres which is a sign of over inflating.
What other reason would you put forward for wear on the centre of a front tyre? Usually tracking will affect the inside and outside. Over inflating will affect the centre, no?Whatever the cause of your tyre tread wear, 38psi was not it!
I can't imagine! Unless they were really dodgy tyres. Your extra 2psi would have gone towards reducing the bulge in the sidewalls, that is where the flex is, not the tread.What other reason
Goodyear Efficient Grip Performance.... so not dodgy tyres.I can't imagine! Unless they were really dodgy tyres. Your extra 2psi would have gone towards reducing the bulge in the sidewalls, that is where the flex is, not the tread.![]()
