161 - 165 of 165 Posts
I releases when ever the charge stops so in most cases that is at 80% although it could be 100% an dnot recommended if done frequently. Every now and then is fine though.
There is the other aspect of someone else using their card... it is almost certainly against the Ts&Cs of the card issuer. Not that people care about such things :)
Discussion Starter · #162 ·
I had someone help me out, but I was there and we agreed a set timer charge (20 minutes). This was because of the @Ecotricity rapid having no signal, therefore it didn't recognise my (new to the machine) card, but his was working fine.
http://ts.la/david3488
Just for reference this attached image shows the charge rate using the onboard meter on the back of one of the newer ecotricity chad/ccs units
Banned
44.4kW is such a weird figure. If correct then the power supply is greater than 63A 3 Phase and it should support much higher power charging... I wonder if the ~44kW is a car limit rather than a charger limit?
I know that the unit at fleet services also has a meter and that did 44.4kW as well.
The picture was somewhere on the M5, but I forget where, Im sad I took it in september ;)
