721 - 740 of 932 Posts
That pack is toasted! What was it like before it hit 100000 miles?
I rapid charge a few times a day soemtines, 7 or 8 within two days to cover the miles I have but never let the pack get above 45' which is easy to do in the current weather. I wonder what Nissan would do as a goodwill gesture along the lines they did for the 24kwh packs in the states?
If it's cost effective I would go back to quick charging in the summer months to help drag it down more quickly and speed up the process to get it replaced under warranty.
I thought all the warranty did was repair battery packs which had degraded below 75% capacity, to bring them back up to 75% again?
Car has driven about 138k miles and warranty details as:
"The Nissan LEAF & eNV200 lithium-ion battery state of health guarantee protects against battery capacity loss (less than 9 bars out of 12) as shown on the in vehicle capacity gauge for a period of 8 years / 100,000 miles* for 40 kWh vehicles and 8 years / 100,000 miles* for 30 kWh vehicles and 5 years / 60,000 miles* for 24 kWh vehicles."
Who are you replying to? No one has suggested replacing it, it's clearly out of warranty, I think it was just posted for reference.
See post 721
Ah, I see your confusion.
The quote is from post 702, referring to the 32k mileage 2 year old battery in post 701.
If you click the tiny up arrow next to "XXXXX said: " on a quote, it will show you the original context.
Final report from me, Leaf gets picked up tomorrow.
30kWh, registered 8/2/17
AHr 76.30
SOH 94.26%
HX 82.65%
Odo 35934
33 QC, 1681 L1/L2
Infact there is mine...
Well my latest update is attached and seem to be doing well. It's been a while since I ran it down to --- and then charged to full overnight on a fast charger and it seems to help with getting the best from the battery compared to all the rapids I do on a weekly basis
not sure whats happened but my previous post in this thread appears to have vanished?
my previous figures have been eradicated...
anyway owned the car for 2.5 months now
24kwh
AHr 60.49
SOH 92.50%
HX 90.63%
Odo 13832
16 QC, 766 L1/L2
2015 (65 plate) gen 2
24 kwh
28,000 miles
SOH 93.5%
Garaged and careful with charging (100% during the week, 80% at weekends)
I try to fast charge once a month.
Don't think I've done this before, so here it is...
2014 Gen2
24Kwh
67,035 miles
SOH 84.6%
I just plug it into my workshop charger every few days. Mostly manually stop it charging between 80 and 90%. Once every few weeks I let it go to 100%, settle for 10 minutes then plug it in again a few times.
2013 reg June registration.
84.61%soh
2nd gen
24kwh battery
43390 miles
Dropped one bar of capacity. Went back up to 88% over last winter but the capacity bar didn't return.
Seems to be very slowly dropping health. Was 88% soh in the summer of 2017 so only dropped 2% per year
84.61%soh
2nd gen
24kwh battery
43390 miles
Mines Aug 2013 and I’m finding pretty much identical results to you.
Dropped to 86% last summer and rose to 88% during winter.
I am experiencing a 2% loss per year and expect my 1st bar loss any time now
Hello,
i am from the Netherlands.
in the summer it is between 20 degrees to 30 Degrees CELSIUS! no fahrenheit!
in the winter between -5 to +15 Celsius
For the guys who like to know how my car preforms in another climate.. here are my stats:
Nissan Leaf 24 kwh December 2013 ( gen2 ) accenta heated front and rear seats,heated steering wheel,folding mirrors etc..
95.000 KM ( 59.375 miles)
AHr = 54%
SOH = 83%
395.55 volt
Hx=75.01
275 QC and 3500 L2's chargings
239 GID'S
L2's are on 10 amps 220volt.. soon i will buy a cable that is 16 amp 220volt.
Bought this car from a guy who used it as a taxi...i bought it with 90.000 km..
he Always charged it to almost 100 procent.
in leafspy its says only 96% SOC..on the car display it says 100%.
i charge to 100% 3 times a week. the rest to 90%..
95% i use 220 volt home charging.. so i only go 4 times a month or so to a quickcharge station.
greetz
Hello,
AHr = 54%
SOH = 83%
395.55 volt
Hx=75.01
239 GID'S
greetz
I don't know if what I do is right or wrong, but I don't think it hurts and it "feels" ok to me. It also may help your Leafspy to report 100% charge...
The way I see it is that the charger cuts off at 100% but the pack is still balancing, so the voltage drops as it balances (transferring the higher cells into the lower ones). That's probably why the % display drops away as soon as you start driving. So once a month, after the charger cuts off, I plug it in again after letting it rest for 10 minutes or so. I do that a few times, until it turns off almost straight away. I always go for a drive afterward because it wouldn't be good to let it sit for any length of time at the full 100%. In between doing it, I charge to around the 80 to 90% mark. Actually, I've just turned on the "long life" mode so it finishes at 80%.
Here is our May 2015 24 kWh
15858 miles
AHr 55.18
SOH 84.38
Hx 79.64
33QC and 804 L1/L2
Was a demo for 1 year then we have kept it between 30 and 80% with occasional 100% charges. Was at SOH 93 just after we got it at 5000 miles. Not sure if I’m a bit disappointed and wondering if the BMS has just lost track of where the battery is at. Perhaps a total discharge gently and granny charge to full may help the figures?
15858 miles
AHr 55.18
SOH 84.38
Hx 79.64
33QC and 804 L1/L2
To be honest id be running it down a few times and rapid charging it to a high % and see if that helps as that's a mighty low amount of rapids you've got compared to slow charges, albeit I know full well a slow charge could only be a few % but still count
