1 - 20 of 34 Posts
Exciting Times Ahead
this will be nice.. they must just keep pushing forward so we can get more miles out of a battery at a lower cost.
Reactions: nattydread
Would be interested to know how much heavier this pack was. Roll on replacement 60 kWh battery packs!
From the article:
More weight, but a lot more power density. Using the 24-kWh pack as a baseline, Nissan says that the new 60-kWh pack weighs just 220 pounds more. So with that older pack weighing in the vicinity of 660 pounds, that ups overall weight to nearly 900 pounds. It's impressive, considering the gain in kWh per pound.
I love this. Well done Nissan, let's see it in a Leaf in a couple of years. All credit for sticking to their principles and keeping it simple = cheap.
And they think hydrogen is the future? :ROFLMAO::ROFLMAO::ROFLMAO:
From the article:
So from 660lbs (300kg) to 900lbs (408kg). That's to allow anyone under the age of 50 to understand the weights.
A 16 stone person is 101 kg. So the increase is the weight of two people with fuller figures. I wonder how that will affect the suspension?
And the tyres? :rolleyes:
Reactions: MoonCat
Or is that only 1 person?
Reactions: Davidx
I was going to say that - these days that's one average teenager based on what I've seen on some high streets
108kg is more like one fat person and their accoutrements. It's not horrific. Chuck out the Bose Sub Woofer thing; revert to Aluminium bodywork (now that there are cheaper ways to make it); tidy up the motor/invertor/charger stack and you can probably get back about 50kg or so. I suspect there are some other weight savings available elsewhere but am not an automotive engineer.
all i want to hear is that it can be retro fitted into gen2 leafs....would be great to pop a new one in like this, or maybe with even more increased capacity, somewhere down the line
There has to be a reason it's still the same size and shape as the current Leaf battery. Yes, they are using it as the test platform so it has to fit but I'm hoping they've got half an eye on a retrofit option in a couple of years.
Reactions: Lee Dalton
I am still sceptical. Toyota don't do it with the Prius, and no manufacturer does it with new generations of engines they produce (even if they go into the same platform) What would make Nissan decide to do it?
Dunno - the power of wishful thinking! :)
Reactions: JDleaf
Appalling residuals on unwanted second hand LEAFs. A second hand LEAF with 60 kWh at about £17k would make it the hottest second hand EV around and depress all other EV residuals unless they did the same.
They haven't (been able?) to do it with the 30 kwh pack to Gen 2
As noted, you cannot have a 30kWh battery in a 24kWh Leaf (officially). They are the exact same car and battery pack, so the chances of the 60kWh one being available from Nissan is non-existent. What I suspect they might do is take all the end-of-PCPs Leafs which have no home and fit 30kWh or 60kWh packs to them in order to make their money back. Bit like Apple offer "refurbished" iPhones.
It's one fatty or two slimer models.
lol. One of those slimer folk I guess. :D
It's this new crappy laptop keyboard with super slim keys. The shift key barely works and the others are hit n miss :(
1 - 20 of 34 Posts
