1 - 4 of 4 Posts
Kona Electric, EU base with heat pump
Other than mistaking the OBC for the BMS, it's a good evaluation and those temps are around what I've measured, 55°C in summer at 32 amps. The OBC is actively liquid cooled as well so its surface temp is not really of any primary concern.
Yes, I like that frunk as well since it uses as much under-hood space as practical.
Kona 64
I've also recorded similar temperatures, the sun on on the bonnet certainly has a warming effect. I noticed that the temperature drops as soon as you drive and airflow cools the bonnet area down.
1 - 4 of 4 Posts
