81 - 83 of 83 Posts
Evening Recombinant,
Mine is an R240. Seems to work ok with the EV Energy app albeit a bit odd. If your charger is an un-tethered you can ignore the difference between flashing green and flashing green LED. It charges as set in the app. It charges for a few minutes straight away when first plugged in even if it is set to 'Smart' charge. But it soon shuts down until the Octopus GO cheap rate starts.
Thanks for the reply. The burst of charging when you plug in is intended to put your Zoe into a fully awake state. I believe that there will be differences between the way your r-series car behaves and my q-series model. Mine is going to the garage for another update in a couple of weeks to see if it can be made to stay awake until the economy 7 time. How long have you had the smart charger?
81 - 83 of 83 Posts
