Back again seeking more help. The truck company I was planning on using for exporting my car are being a pain. I'm looking at heading over myself to collect the car and drive back on Saturday. Looking like it will take 4 fast charges on the bounce and then hoping to use Dragon charging in Fishguard, normal charge and then two more fast charges on the way home from Rosslare ( Ireland )
Will the 4 fast charges on the bounce be detrimental to the battery?
Is the Ecotricity network reliable or should I used something else? Looks like I can just install the app, register my card and pay as I topup which should be very handy.....
I would try to be as close as 20% or below at charging station. I read somewhere that (for the 40kw) if you wait 5 to 10min after charging to allow the battery to cool down a bit it will allow you to travel further without trouble.
When I went to London 1,5 yrs ago I charged 5 times and got to London with the temperature just under the red. But that was because I didn't knew the car that well and charged more frequently than I should have.
You should be able to make at least 80 miles (128 km) between charges.
I've driven similar route on M4, N London to N Somerset, once in a 24kWh Leaf for shiz and giggles. I drive this route regularly in a dirty diesel.
Always have plan B.
There is a Moto Reading service, use Ikea as plan B.
The Moto Leigh Delamere service only has a single charger, not the best place to stop with only 25%, when next charger is in Bristol. I'd top-up at Welcome Break Membury, treat Leigh Delamere as plan B.
I see before your Newport Holiday inn Express, there's a Roadchef Magor. Worth calling in at Roadchef and leave Holiday inn as plan B.
Finally, a 4th charge in depth of Wales.
Generally, Chademo on Ecotricity is pretty reliable.
Battery temperature is your only concern. If it's nearing red, slow down slightly.
Always have plan B.
Thanks for that's. It's something I hadn't considered and will amend the route. I'm assuming I can add all the chargepoints as waypoints in Google Maps and that should set me straight....
The way I would put it is don't rely on any one charger you don't know well. You should have a plan B for each charger I think so that you can't fail unless you have 2 consecutive charger fails.
Final route is planned. Main stops in yellow and Plan B's in white. I'm sure I could have stretched them out a little further but hopefully this is fail safe. Naturally the shorter distances should allow
me to travel a little faster, I'm going to use that time to give the battery some time to cool down pre and post charging. TIme should not be an issue as I've a long wait for the ferry in Fishguard..
I would suggest slowing down to 63mph rather than trying to cool the car prior to charge. That's way too many stops and is you push the speed, battery is going to be in red
- Leaf 30 kWh
If you drive at 70mph only to plug in to slow charger, I think your are better off driving slower to reduce temperature buildup.
Leaf takes good rest overnight to move to red to 8 bars (Sheffield with ambient temperature 17C). It cool further sitting the day and driving at 63 C and I rapid didn't b push it back into red during return leg
- Leaf 30 kWh
Well my Leaf24 gen2 had another Nissan major service and MOT today no adviseries total cost £263.85, i know this on the high side but it preserves the full dealer service history and 12 months RAC cover so i cant complain.The young lady said when i collected all is good Mr Steele battery check...
Scenario; Sun 8th, depart New Mills (200m) on 100%, steep down to c140m, then long steady climb to Rushup Edge at 428m, short v steep down Winnats Pass, trundle along Hope valley to 148m, left up through Bamford, Ladybower, to Moscar Heights 360m, uplands lanes then steep descent to Dungworth...
Hi all,
Just need some advice please. I've seen a Leaf at Nissan dealers in Colchester which is around 130 miles away from me. 2016 30kwh 50k and 2 owners. Price is £12495
They were unable to provide me the battery SoH and the only thing they provided me in terms of the battery health was this...
Hi folks, I have a 2015, 24kwh Tekna. Since buying the car 2 years ago, I have had climate control set on 'auto' between 20/21 degrees. If it's cold, on startup, the heater blasts hot air out of the central and side vents warming up the car in no time, I love it. I've been using the 'Myleaf' App...
Hi just about to purchase 2017 30kw Leaf 22,000 miles for fair price from Nissan Dealer. They tell me that they check the health of the battery and use a star rating which strikes me as not all that helpful. I've told them I will do a Leafspy check and just wondered what would be an acceptable...
