1 - 15 of 15 Posts
Just went to the boot on my Ampera and I noticed that when the boot is shut, it appears to be twisted.
Automotive parking light Automotive side marker light Automotive tail & brake light Car Grille
Automotive parking light Automotive side marker light Automotive tail & brake light Grille Vehicle
As you can see the gap is greater on the right hand side than it is on the left. I've also noticed that the boot lid is rubbing on the bumper. Does anyone know of a way to adjust the boot lid? Even if it's only a couple of millimetres, just to stop it rubbing.
Electron Summit White NK13...110k 92.7 and rising
There are a couple of bump stops hanging inside on the tailgate which have a habit of falling off. Suggest you check that those are both there first.
If you need a replacement then ones for Range Rover Sport Disco 3/4 Freelander2 CFM500010 will fit. Get them off ebay for a fiver a pair.
It's definitely shifted left isn't it - you can see from the taillamp units. Just tried pushing mine but it doesn't give that much - hardly at all. My catch is slightly to the right of centre if anything.
If it was the latch position pulling it over it would presumably centralise as soon as you lifted it up?
What is the alignment like at the front edge where it meets the roof?
Sounds like you've got it then. A little shim under one of the hinges should do it. Doesn't answer the question why though. Has it ever been in an accident?
I thought about adjusting those. Gotta find out how to get to them now.
Be careful - you'll need a friend. It looks very heavy.
You'll probably need to adjust the latch once the door is square. The trim panel comes off quite easily if you slip the rubber seal back and lever it off where the blue clips are located. There are separate little covers that you can lever off the luggage retaining tabs. Here is a pic of mine which just happens to be off at the mo' as I'm fiddling with trailerboard lights (for a cycle rack before everyone tells me its not approved for towing o_O )
141611
I've not looked at it and I'm sure it will be obvious if I do but for me I'd have been looking at the bit on the car not the lid for the striker.
But I'm so impressed with this forum, never fails to deliver!!
1 - 15 of 15 Posts
