Though most Type 1 configurations are 3kW (13A), I once read in the standards that Type 1 plug is rated to maximum 11 kW (45A).
According to Wikipedia, the maximum current for a Type 1 connection is 80 amps.
https://en.wikipedia.org/wiki/SAE_J1772 Most vehicles using this connector have 3.3 kW or 6.6 kW on-board chargers, so can't use anywhere near that 80 A.
My understanding is that 3 phase means 3 wires (1 phase means 1 wire): 2 or 3 wires can be combined into 1 wire by various mechanisms (e.g. single phase converter). Why resist conversion from AC 3 phase to AC 1 phase when conversion to DC (1 phase) is unavoidable? Can you quantify the extra efficiency loss?
Three-phase power needs 3 line and 1 neutral wire, unless the device connected draws exactly equal current on each phase, in which case the neutral wire carries no current and can be omitted. Old-ish large induction motors often run on 3-phase power and don't need neutral, but for wiring an office, farm or factory it is necessary.
If a Type 1 plug can deliver 11kW, then it could be plugged to a maximum of 26A on phase 3, which seems perfectly within tolerance of EU 3 phase electricity supplies. It would appear there was no engineering constraint that necessitated a 3 phase plug for the EU: So unless that is a substantial efficiency loss in 3 phase to 1 phase it appears the EU simply created a novel market standards to exact political control (as it so often does).
The necessity is that in a lot of continental Europe, many, many homes have low-current 3-phase mains supplies, rather than higher-current single-phase as is near universal in Britain. To avoid the 5-figure price and significant disruption of running a new mains cable to each home, a car plug and socket was needed which is compatible with the existing power system. Choosing a single standard plug which can be used for either 1-phase or 3-phase mains, rather than leaving it to individual car manufacturers to introduce their own, made absolute sense.
Most new EVs seem to be made with three 3.6 kW AC-DC conversion modules for battery charging, and switch in one, two or all three across 1 or 3 phases, depending on what they find themselves connected to. That leads to efficient conversion (each module runs at its rated power) and charging from 32 amp 1-phase or 16 amp 3-phase, well suited to home charge points.
In any case, at a practical level all of the EU shenanigans have been irrelevant in UK, USA and Japan because these regions rely on phase 1 supplies. As the UK is now outside of the EU, why is any emotional hoo-har for a 3 phase plug (with redundant copper that will never transmit energy) persisting?
Japan and North America mains power is technically 2-phase 120 volts, which means for connecting purposes you can use either 120 or 240 volts along 2 wires. Plus a third wire for the protective earth.
If you are environmentally conscious, why use a cable that contains up to 66% unusable materials?
If referring to the thick copper power conductors in the cable, that's at most 40% unused, not 66%. Single-phase charging cable needs line, neutral and protective earth, total 3 thick wires. Three-phase needs line 1,2 and 3, neutral and PE, total 5 wires. The extra half a kilogram of copper in a type 2 cable is not much compared with all the copper in motors and cables and inductors inside the car, and copper has an efficient and fully used recycling market (that's why there are cable thieves: scrap copper is valuable). Not a significant environmental cost, compared with running a car at all.
It is a bit wasteful that the Type 2 standard doesn't allow a single cable with 32 A single phase and 16 A three-phase, which would reduce the weight, cost and amount of copper in the lead coiled up in the boot or froot. (3 thick and 2 thinner wires in the cable.) The standard doesn't have any way the cable can give such detailed information to the car - it's just a resistor to code the maximum current.
