1 - 20 of 42 Posts
2018 e-Golf
Pulled in to the tyre shop because I had a flat and tread was low anyway and the fella tells me because I have a “GTE” I have to use the same tyres or it will drain the battery 3 times quicker….
facepalm.
Reactions: cah197
Well you do want low rolling resistance ones, preferably low noise, and thery're probably a high weight rating, so does depends what's available in the size you need...!
Reactions: TJEV
facepalm.
And if you don't use the same air that's in the old tyres it will drain 4 times quicker!
2018 e-Golf
Fair enough, but he was adimant it had to be the EXACT same. The DUnlops on there were D rated for economy and the new ones I had him put on are B! so if anything its going to marginally increase the range!
They should be identical on each axle - i.e don't mix types on one axle but I'm sure it's not illegal to do so in the UK provided the tyre specs are the same in all respects. (size, load rating, XL/not XL)
2018 e-Golf
Absolutely. I was getting both fronts replaced anyway as the tread was very low.
2018 e-Golf
Discussion Starter · #8 · (Edited)
What did you fit?
I have crappy Dunlop Enasavers on the rear and the excellent Michelin Primacy 4S2 (A for efficiency) on the front.
Dunlop Blueresponse i think they are. I just go on the A-E rating of economy and grip and get something mid range,
The back ones are Hankook and i think they are E rated :ROFLMAO: previous owner put them on but they arent even close to wearing out
I have an Etron on lease. Lease includes replacement tyres. Lease firm is well know for being tight and minimises expenditure by normally insisting that replacements are much lower cost variety than those fitted at point of delivery and do not put matching tyres on same axle.
However, when I had a puncture which could g be repaired I was surprised to be told by lease firm that because the Etron is 4x4 all 4 tyres must be of same variety, ie the replacement must match the three factory originals. Bonus!
If there is any truth in this, I assume it applies to all 4x4s? ..... including many EVs?
2018 e-Golf
Discussion Starter · #12 ·
We had the bluresponse on our golf. Efficiency thumbs up. Soft sidewall wiggly borderline unsafe handling, serious thumbs down ...
Oh dear! Well it’s done now so we shall see!
Mercedes EQC 400 4matic
I hope you read the death from tyres on the front contributions on the Soul part of the forum🤗
The example was an attempt to make a serious point. Loosing control of a car in that case had fatal consequences identified in the coronors verdict. We are all far too blase about safety and just because we think we know better we take risks we should not. There were some reasonable arguments made as to why people felt it was better to put new tyres on the front and it certainly seems counterintuitive not to but the testing evidence shows simply it is not a good practice due to the aquaplaning problems. On another forum I follow a chap luckily walked out of a wrecked e class saloon which was travelling at 130km in a straight line on a motorway, no other traffic and the car aquaplaned it ended up rolling several times and just stopped on its roof before smashing into a bridge. Guess what, he had new tyres on the front and asked they be fitted there as the back were in pretty good condition. Now if all you do is pootle about in a city car with no motorway or dual carriage way driving you will probably be fine as you are less likely to be travelling at a higher speed and can correct things if it goes wrong and if you crash it will be less severe but those going onto motorways should think carefully. For my part sharing the roads with other drivers I would be grateful if you would listen the the experts😉
Groan. If you want to be safer, slow down and drive to the conditions. Take a break at regular intervals on long trips. Don't get distracted by tech in the car. Take an advanced driving course. These are all the real world steps that EXPERTS advise and practise.
Add 'car control' to the list.
The first thing I do when changing cars is to explore the handling limits on dry, greasy or wet roads. (traffic free in case it goes horribly wrong)
I then know what to expect on the limit (eg emergency avoidance) - lift off oversteer, roll oversteer, understeer, drastic understeer, a neutral drift or total unpredictability. It's a bit late finding out the hard way!
Yep, many people speed up in poor conditions which I’ve always found odd. Scatch that most people just speed.
Last year, for example, I stood and watched a stupid cow batter along well in excess of the speed limit on black ice. She then expected her 2 ton PCP 2WD SUV to go round a tight corner. I’ve never laughed so much as she ended up in a garden 🤣🤣🤣 These people never learn...
On the upside, driving for thirty years with hundreds of car/tyre combinations never had a bum clenching moment.
Speed limiters are probably a better idea than worrying if the front tyres have 1mm more than the rear...
I laughed at my neighbour 20years ago. He had a Disco and made the mistake that having 4wheel drive meant it could corner regardless of the conditions. It only dawned on him that front grip is not improved by having the rears driven as well when he ended up in a ditch.
1 - 20 of 42 Posts
