Hi guys,
I posted this in the e-NV200 forum too, as that's the vehicle I have, but it's quite a general point so might be of interest to everyone...
So I'm just planning the electrics system for my e-NV200 camper conversion and had a thought...
In the past (in ICE campers) I've always used leisure batteries for the camper electrics, charged from the alternator via a battery-to-battery charge system (as well as solar and a 230v mains charger). But, in an electric vehicle, is there any reason I can't use the 12v under the bonnet?
Conventionally, the starter battery in an ICE vehicle will deliver a high surge current to start the engine, but won't like being deep discharged. Your leisure battery is the opposite and won't deliver a huge surge current, but will be more tolerant to bring deep discharged. So as far as I can see, the main reason for using a specific leisure battery as opposed as a starter battery, for your camper electrics (other than the obvious reason of not draining your starter battery whilst camping) is because the two batteries are actually different technologies (one for high surge low discharge, and the other for low surge but high discharge)
So it got me thinking... why can't I replace the 12v battery under the bonnet of my e-NV200 with a high capacity battery (maybe AGM or lithium) of 200Ah, and use that to provide 12v power to both the vehicle, and the camper 'leisure' electrics?
Our EVs don't pull a surge current from the battery when they start - they just use the 12v to keep systems running and boot up the vehicles drive systems etc. So if there's no surge current required, a 'leisure' type battery should be able to replace the factory 12v, no?
The benefits that I can see are:
*Only one 12v needed in the vehicle rather than 2, saving weight and space.
*No battery-to-battery charger or split charge relay required.
*No additional 230v mains charger required for the leisure battery, as the 12v charges when we plug the vehicle in (I assume?)
*There's plenty of space under the bonnet to fit the inverter and solar charge controller.
The only negative I can see is that you'd need to ensure that you don't drain the battery (rendering you unable to start the vehicle). Or does the vehicle sense when the 12v is low, and charge it via the DC-to-DC, automatically? Either way, you can fit a voltage sensitive relay, that cuts power to the 'leisure' system when the battery gets to a certain percentage state of charge, to ensure that there's always power available to start the vehicle.
Any thoughts on this? I'm sure many of you guys are far more clued up than me
Sent from my HD1903 using Tapatalk
