Well I've never heard of such a rule and rules are just rules! Even if it were PAYG it would be a friendly gesture between EV-pals!I am sure there is some dreaded OLEV rule ----
Someone planning to use a 7kw charger isn't likely to be in any sort of hurry, so it's not quite the same deal.It's an interesting problem. I doubt someone with a 7kW charger will think too much of a 3kW Leaf blocking a 7kW post either if they are forced off onto a 13amp socket.
How does this work when the majority of 'rapid' charging locations have one charger?1. Rapids are for rapid charging and short stay parking only. If your car doesn't support it, or you din't NEED to rappid charge, use a 7kw station.
I was going purely on the example in the video.How does this work when the majority of 'rapid' charging locations have one charger?
Very interesting, and I enjoyed the videos - but I took the above photo when I was blocked from charging by the same i3 the following day.It this guy, http://myrenaultzoe.com/index.php/author/alloam/ have not got time to look for the other video but I'm sure you will find it put his name in to YouTube you will find. Yay found it
So it's basically a question of the i3 owner grabbing the space nearest the exit door....?Very interesting, and I enjoyed the videos - but I took the above photo when I was blocked from charging by the same i3 the following day.
Sorry forgive the ignorance but why would the rapid be slower, I thought they were 40kw ish... most of the posts are 7kw with some 22kwOne of the problems going forward is that many drivers won't know the charging rate and I have no doubt that many i3 and Tesla drivers will end up using the AC 'rapid' connector because they think it's faster. Certainly many of my friends buying these cars are non-technical.
IMO the only answer is more charging hardware![]()
ok I get that with the i3 what about the tesla, its limited to 11 or 22kw depending on 1 or 2 chargers fitted so why would it be slower on the rapid than a 22kw post ?It is slower because the i3 can use the AC 43kW side of a rapid charger but it will only charge at 7kW as it cannot use AC for fast charging... only DC through CCS.
(5. If you've got a Leaf, go and hire a real car?)(4. If you've got a REX fitted, go to a petrol station?)
If its' a 22kW Model S then it can charge at 22kW regardless of whether it's the AC cable on a 'rapid' charger or a AC Charging Station.ok I get that with the i3 what about the tesla, its limited to 11 or 22kw depending on 1 or 2 chargers fitted so why would it be slower on the rapid than a 22kw post ?
I agree it has to be first in best dressed, however a way to contact the owner and ask if you could jump the queue is a good compromise.Getting into debates about who deserves the power the most is going to end in tears.
Totally agree and I would always offer to help anyone if they asked and it was convenient enough for me to do so.I agree it has to be first in best dressed, however a way to contact the owner and ask if you could jump the queue is a good compromise.
Decent people would let someone jump in if it was the right thing to do
Very constructive, that.I'm done with this thread(5. If you've got a Leaf, go and hire a real car?)
So that rapid was blocked for two hours when it could have been available. I don't doubt that it was a simple case of a new owner not knowing the issues but it can only gets worse.After a couple of minutes mastering the options provided by the numerous buttons on the charging unit, both car and charger reported that all was well and charging commenced. A couple of hours later we returned, unplugged and set off for the exit
It was a post on a personal blog, not a forumI hope you replied on the Leaf forum.
